-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
CypressMidWest 10-15-2003 11:17 AM
Originally posted by fReShJiVe
yes, if you change the rear pod plate you could use the assoc. t-bar but not with the stock Kawada rear pod plate...yes front end will also fit but you have to change the whole front end...none of the front end is compatible with each other maybe the turnbukle and the upper arm ball end....so with all the changes done it really isnt a 12L...maybe by looks and performance it is;)
Cool, the original question I was answering was whether or not the Riemon M300 Chassis could be used with the stock AE pieces, and by your description it can.
Keith Billanti 10-15-2003 12:06 PM
quad 12
I am trying to get ahold of the guy who makes the quad 12... any suggestions? I have emailed and PMed him...
if anyone has info.... drop me a line..
KB
speedxl 10-15-2003 12:10 PM
he and his wife are on vacation kieth i run for him do you need help with something.
speedxl 10-15-2003 12:15 PM
that is a reiman chassis and the kawada and the majority of the jap manufactures especially yoko use all the associated running gear for the exception of the rear pods which they do for the reason to identify the cars.
SteveG 10-15-2003 02:27 PM
Originally posted by racerdx6
When I accelerate from a slow speed or from a dead stop my car spins to the right. Usually not very helpful when you make a mistake and slow way down and than accelerate too hard and swing into the boards again ;) . I was thinking I could try going up on a pinion tooth, or mabey try green springs on both sides of my motor. Currently I'm running a monster stock with red +/ green - spring combo. Very fast. But the acceleration is almost too good. What do you guys think?
I have an AE 12l3 and mine goes left when punched at slow speed or from a stop :confused:
I have checked and rechecked my tweak settings on an MIP Tweak tool and with a digital height gauge on a dead flat surface plate and it appears good. I use very little preload on the tweak screws, just enough to hold the T-Bar.
Scratchin my noggin here....everything looks good so I don't get it why it darts left :weird:
Could it be chassis flex ??
Big KAT 10-15-2003 02:47 PM
One last thing to check is the motor wires, they can cause a tweak or get pinched between the chassis and body. Good luck!:)
sands 10-15-2003 02:58 PM
If it turns under acceleration, you might have the punch level set to aggresive. Or just on the throttle more smothly.
Sands
stormperson 10-15-2003 03:26 PM
I dont know much about t-bar cars but here are my guesses:
-try replacing the t-bar just incase its is soft or something
-back out the tweak screws
-make sure that there is no undampened uptravel in the front end, or anything wrong with the front end. Strut front ends are hard to bulid properly so that the castor is equal on both sides and so that nothing binds, they also get dirty easily, so that might be it.
There are alot of things that it could be, I would go step by step and try to eliminate as many things as possibe.
spyderx 10-15-2003 06:00 PM
Storm-
Remember what was tweaking my car last weekend and causing it to spin going into corners... rear ride height. Make sure your rear ride height is about 3-4mm, no more. Make sure the car is tweaked right. Check your tire diameter and make sure they're the same.
When a 12th scale is setup right, you should be able to punch it from a stop and it won't go anywhere but straight.
stormperson 10-15-2003 06:25 PM
That was interesing wasnt it? lol:D
Spyderx makes a very good point, before doing anything else make sure everything is mechincaly correct and reasonably set up, since silly stuff like a few mills of ride heigh can REALLY throw off handling.
There can be a thousand things that could be causing a problem, however normally when you fix the basic stuff the car gets alot better.
TigeRyan 10-15-2003 07:39 PM
Hey All,
Just getting into 1/12th scale...so I hope you don't mind some newbie questions...
I bought a CRC Carpet Knife 3.1 and I love the car, thing is handling fairly well, have a slight oversteer to the right, but I think I know where that is...
My biggest question is, I can't seem to find the correct gearing for the car...I am running indoors on a fairly large carpet track using 19 turn motors...The car has a 100 tooth spur in it...I know tire diameter plays into the gearing, but I don't have the car in front of me so if someone could give me a ballpark and I will adjust from there...
Thanks in advance,
TigeRyan
sands 10-15-2003 08:23 PM
depends on tire diameter. go to the bottom of page 146 for a rollout chart.
TigeRyan 10-15-2003 08:49 PM
Ok, I am looking at the chart, my tires are 1.880" with a 100 spur...that leaves me with 6 combinations...so where do I start?
spyderx 10-15-2003 10:22 PM
I'd start with a 28 or 29, right around where you'd start with a stock motor.
Manfredo 10-15-2003 11:20 PM
Hello !
I decided to try 1:12th scale and bought a RC12 car. I plan to go with 4 cells and a 12 turn motor.
What servo would you recommend for 12th scale. (mid range price) ?
What tires should I buy to get a good starting point on carpet ?
