Originally Posted by seth556
(Post 14688281)
Next year we can see the release of "SXT 3.0 Organic Artisan Blend." You'll be able to buy it at all natural hobby shops.
Originally Posted by ColinH
(Post 14688763)
My AE I could run them to plastic and still have a 3.5mm ride height, my x12, already down to 3mm.
Has anyone else run I to this problem? If so, how'd you fix it? Thanks, Colin |
Originally Posted by fenton06
(Post 14688831)
Might be a stupid question... But I'm ASSuming you have all the shims out? If so not a lot you can do. I ran my car at 3mm and had to quit using my tires at around 40mm iirc.
(Post 14689023)
Correct, no Shims, tires at 40.95.... guess I will have to start truing them a tad larger...
I seem to recall putting shims under the spring, having removed them from above the upper arm etc to 'jack' the car up slightly. |
Originally Posted by Skiddins
(Post 14689211)
Have you tried rearranging the king pin shims to change the ride height?
I seem to recall putting shims under the spring, having removed them from above the upper arm etc to 'jack' the car up slightly. So, once my tires get to 41mm I guess someone running a CRC will be super happy, $20 a set... lol. |
Originally Posted by LonnyJ1950
(Post 14687652)
Ax wax stated above, take something like Jack the Gripper and coat the tires lightly and seal them in a plastic bag the night before. In the morning the tires should be dry again, but much softer. More front caster may help corner exit, on one very low grip track we were running 8-10 degrees. Harder fronts, stiffer front spring, a bit of toe in, less camber. You may even need to stiffen your overall set-up. Nothing is worse in a low grip situation than allowing the chassis to drag. You could also add an extra lip spoiler to the back of the body, and mount the body slightly rearward. You're trying to make the car understeer. Do what you have to to max out the rear grip, then add steering back in to balance the car.
I really appreciate all the helpful ideas. |
Colin, machining the front arm mounts might be the only option.
There's a few brands I've noticed that have this limitation. I switched to an RSD T2 car with a double wishbone front end and their version of A slider pod and you can run that to the rims easily. |
(Post 14688763)
Hey guys, picked myself up a new 12th scale, coming from an associated 12r5.2, where you can sand the front bulkheads down to get maximum ride height adjustments and run tires that aren't enormous, only to throw them away when they reach optimum diameter, I have one issue with the x12...
I am struggling to keep a ride height of 3.5mm because I do not have the adjustment I used to have with the 12r5. That being said, my tires are at 40.95mm as it sits, and I am at a 3mm ride height... reason I like 3.5 is because we have the CRC Black carpet, and our track is bumpy. The car turns on a dime, set up is perfect, but I still would like to keep using a set of tires that have plenty of life. My AE I could run them to plastic and still have a 3.5mm ride height, my x12, already down to 3mm. Has anyone else run I to this problem? If so, how'd you fix it? Thanks, Colin |
My x12 is the same.
Originally Posted by InspGadgt
(Post 14689550)
Strange...I don't remember having an issue with that on my X12. I ran on asphalt so I had to change the tires out before they got to the rim but still did run right down to the rim a few times. You could probably sand down the arms like you did the arm mounts on your AE...but you'll need to sand down the inserts as well.
Alright, well, I usually true my tiers 41.5 front, 42 rear but, looks like I will start truing 42.5 front to give me a couple more races out of them. They seem to go half a mil per race night. A lot less than our old carpet. |
Originally Posted by HK500Pilot
(Post 14689425)
Thank you for the information, I'll report back with how my test and tune session goes.
Originally Posted by Race19s
(Post 14688398)
Thats false. And Im in the Solvent/Chemistry field. By no means is SXT healthy for you, but the type of hydrocarbons used there vs Paragon types is night and day.
" Wayback Machine http://home.sc.rr.com/mlufaso/rc/Paragon.html All things are poison and nothing is without poison. It is the dose that makes a thing poisonous. Paracelsus 16th century pharmacologist I would like to clear up some, in my opinion, misconceptions about the safety of the chemicals found in tire traction compounds, most notably Paragon Ground Effects. One of the chemical components of Paragon Ground Effects traction compound is methyl salicylate. A major chemical component found in motor sprays is hexanes. I have listed a link to the MSDS at Cornell and extracted health information from the MSDS for these two chemical compounds. At the bottom if this document I list a common household chemical found in nail polish removers for comparison. Methyl salicylate is also found in common items including muscle pain relief (e.g. Theragold, Icy Hot, Ben-Gay) and root beers (e.g. source 1 and source 2 and source 3). Sometimes a chemical can have a strong smell, but be non-toxic. On the other hand, something that has no smell or smells sweet could be highly toxic. A racer's sense of smell is not a good indicator of the safety of a chemical. Going to an odorless traction compound should not be done for safety and health reasons, unless the safety of the alternative(s) is(are) known. In my humble opinion, it would be benificial for all manufacturers to be required to list the components in the tire traction compounds that are sold. Racers could ask each company to release the information as to what is in their products. If the company is unwilling to release the information regarding the contents, then the racer could contact the Consumer Product Safety Commision and find out their rights as to the knowledge of the chemicals that are sold in the traction compounds. I think we as racers would be much better off to have the companies voluntarily release the content information, rather than being in an outside government organization. I would be more than happy to list the MSDS sheets for each compound upon request. If tracks are going to outlaw certain traction compounds because of odor, then I would certainly want to know if the 'odorless' traction compound is going to be worse for my health. The relative risks involved in skin and inhalation exposure to oil of wintergreen in Paragon Ground Effects, in my opinion, are low compared to exposure to the chemical compounds found in motor sprays. I have more concern for a racer's health and long term safety with the use of motor sprays, because it is more irritating to skin and overexposure will cause more damage. (It should be noted that hexanes are still relatively safe and better for the environment compared to 1,1,1,-trichloroethane used in the past.) From a health point of view, I feel more comfortable using Paragon Ground Effects than other traction compounds with unknown ingredients that may be much more harmful to my health, but I don't know - without knowing the components. If the racing companies are willing to list the components of traction compounds, I will list the MSDS sheets and share my opinion on the relative safety of the various brands. I believe that most of the ill health effects at tracks are related to the use of motor sprays rather than traction compounds. Of course, at this point one should go to the top of this page and read the first two lines which has been known for 500 years - dose does matter. Both methyl salicylate and hexanes are relatively safe, but one should try to limit the exposure to each to reduce the ill effects. methyl salicylate (synthetic oil of wintergreen) Health Hazards Acute & Chronic: MAY BE IRRITATING TO SKIN/EYES.HARMFUL IF SWALLOWED.DRINKING RELATIVELY SMAL AMTS (10-30ML)HAS CAUSED POISONING & DEATH SIMILAR TO THAT SEEN IN ASPIRIN POISONING. Signs & Symptoms of Overexposure: TARGET ORGANS EFFECTS:REPEATED DAILY APPLICATION OF LG AMTS TO SKIN OF RABBITS HAS CAUSED KIDNEY DMG.EFFECTS IN HUMANS UNK.EXCESSIVE EXPO MAY RESULT IN SIMILAR EFFECTS.REPEATED DOSING ORALLY/DERMALLY OF LG AMTS TO RATS HAS CAUSED REPRODUCTIVE EFFECTS.EFFECTS IN HUMAN ARE UNK.EXCESSIVE EXPO MAY RESULT IN SIMILAR EFFECTS Carcenogenicity Indicators NTP: NO IARC: NO OSHA: NO Hexanes Health Hazards Acute & Chronic: INHALATION: HARMFUL. MAY CAUSE NERVOUS SYSTEM INJURY. SKIN: IRRITATION. HARMFUL IF ABSORBED. EYES: CAUSES IRRITATION. INGESTION: LOW ORAL TOXICITY. Signs & Symptoms of Overexposure: DIZZINESS, GIDDINESS, HEADACHE, NAUSEA, BLURRED VISION, LOSS OF APPETITE & WEIGHT, NUMBNESS, WEAKNESS OF ARMS & LEGS, IRRITATION There is debate on the cancer causing (carcinogenic) ability of many chemicals. Toxic List Note that unleaded gasoline is a carcinogen (to the State of California). How does the MSDS compare to other household and racing chemicals? Nail Polish Components (butyl acetate, ethyl acetate) and Nitromethane Ethyl acetate Health Hazards Acute & Chronic: ACUTE: VERY DANGEROUS IN CASE OF INGESTION. SLIGHTLY DANGEROUS TO DANGEROUS IN CASE OF SKIN CONTACT (IRRITANT), OF EYE CONTACT (IRRITANT), OF INHALATION. VERY SLIGHTLY TO SLIGHTLY DANGEROUS IN CASE OF SKIN CONTACT (PERMEATOR). SEVERE OVER-EXPOSURE CAN RESULT IN DEATH. CAN BE FATAL IF INHALED OR INGESTED. THIS PRODUCT MAY IRRITATE EYES AND SKIN UPON CONTACT. CHRONIC: THE SUBSTANCE IS TOXIC TO LUNG S, MUCOUS MEMBRANES. REPEATED OR PROLONGED EXPOSURE TO THE SUBSTANCE CAN PRODUCE TARGET ORGANS DAMAGE. REPEATED EXPOSURE TO A HIGHLY TOXIC MATERIAL MAY PRODUCE GENERAL DETERIORATION OF HEALTH BY AN AC CUMULATION IN ONE OR MANY HUMAN ORGANS. ... State Regulatory Information: ETHYL ACETATE IS LISTED BY THE STATE OF MASSACHUSETTS AND THE STATE OF PENNSYLVANIA. WARNING: THIS PRODUCT CONTAINS A CHEMICAL KNOWN TO THE STATE OF CALIFORNIA TO CAUSE CANCER. WARNING: THIS PRODUCT CONTAINS A CHEMICAL KNOWN TO THE STATE OF CALIFORNIA TO CAUSE BIRTH DEFECTS OR OTHER REPRODUCTIVE HARM. Butyl acetate Health Hazards Acute & Chronic: INHAL:IRRITATION OF MUCOUS MEMBRANES, HEADACHE, NAUSEA, VOMITING, DIZZINESS, DROWSINESS, IRRITATION OF UPPER RESPIRATORY TRACT, UNCONSCIOUSNESS, MAY CAUSE NARCOSIS. SKIN:IRRITATION, PROLONGED CONTACT MAY CAUSE DERMATITIS. EYE:IRRITATION, MAY CAUSE TEMPORARY CORNEAL DAMAGE. INGEST:HEADACHE, NAUSEA, (EFTS OF OVEREXP) Signs & Symptoms of Overexposure: HLTH HAZ:VOMITING, DIZZINESS, GASTROINTESTINAL IRRITATION, CENTRAL NERVOUS SYSTEM DEPRESSION. TARGET ORGANS:EYES, SKIN, RESPIRATORY SYSTEM, CENTRAL NERVOUS SYSTEM, MUCOUS MEMBRANES. CHRONIC:NONE IDENTIFIED. Nitromethane Health Hazards Acute & Chronic: ACUTE: HARMFUL IF SWALLOWED, INHALED/ABSORBED THRU SKIN. CAUSES EYE & SKIN IRRIT. VAP/MIST IS IRRIT TO EYES, MUC MEMB & UPPER RESP TRACT. ABSORPTION INTO BODY LEADS TO FORM OF METHEMOGLOBIN WHICH, IN SUFFICIENT CONC, CAUSES CYANOSIS. ONSETMAY BE DELAYED 2-4 HRS/LONGER. TARGET ORGANS: LIVER, KIDNEYS, (EFTS OF OVEREXP) Signs & Symptoms of Overexposure: HLTH HAZ: CNS. TARGET ORGAN DATA: BEHAVIORAL (SOMNOLENCE, ATAXIA); LUNGS, THORAX/RESP (RESP DEPRESS, RESP STIMULATION); LIVER (HEPATITIS: HEPATOCELLULAR NECROSIS, ZONAL); KIDNEY, URETER, BLADDER (CHAN GES IN BOTH TUBULES & GLOMERULI). The views on this page are only those of Dr. Michael Lufaso. I'm not a medical Dr., nor do I practice medicine, but I have a Ph. D. in chemistry. They do not necessarily represent those of any of my past or present employers. Any use of information contained in this webpage is at the reader's own risk. I recommend that you limit your exposure to all chemicals and solvents in racing, but keep in mind that many of your household chemicals are more dangerous to your health." Also: http://www.rctech.net/forum/2286322-post215.html |
I have a question to ask about additives and I don't even race 1/12th: Why do people use additive instead of just bolting on a softer/more grippy tyre?
My understanding is additive softens the tyre, so how is that different from just using a softer tyre? Thanks Mike |
I think you guys are making a big deal out of not much when it comes to the toxicity of tire traction compounds. the main ingredients of Paragon are probably oil of wintergreen, toluene, and hexane, where as odorless primary ingredients are mineral oils and other non-volatile stuff such as nitromethane, detergents similar to those in transmission fluid and that sort of thing. Non-volatile organics are almost always not as bad for you as the volatile because you're not breathing it and its harder to absorb through skin. That being said, if this stuff we use was that bad for us, how long would we actually be using it? We aren't brewing this in someones garage, its made by a company with lawyers and shit. Don't worry about it, just try to keep it off your hands if you like.
(Post 14689572)
That's what I don't want to do. Shoot. Lol.
| All times are GMT -7. It is currently 09:31 AM. |
