1/12 forum
hey guys, i need some help as a new member to the new 1/12 brotherhood i need suggested rollouts for a 13.5T motor....90 x 46 track approximate. i have a Schuur Speed motor...43 degrees timing. Just suggested...i don't want to be completely out to lunch when i hit the track. thanks!
i raced years ago...but so much has changed!
thanks guys! i ran around 89mm last weekend on this track...it was okay but it was my first time out in alot of years. my driving needed more help than me changing pinions to go faster. as the day progressed i cut my tires down and the rollout then was around 87-88....seemed quicker and ran the most laps of the day for me. i will continue to drop and see if it picks up even more.
the motor never got above 120 degrees and there was very little fade.
85 rollout, 40-45 timing should put you close
You mean like this? http://www.tqrcracing.com/shop/produ....asp?p_id=6920 Or are they different than the Standard ones? I don't remember... I guess 4.40 like above would be better I guess...
Hello all, what is the best way to route the motor sensor wire on the Associated 12R5.2 without it rubbing on or hindering the rear pod? Should it be kept along the same path as the motor wires or somehow fished between the pod and body mount support?
Thanks for the help!
2991Likes
