Like Tree2991Likes
1/12 forum
Old 01-31-2015 | 03:59 PM
  #42031
Is there a reason to run huge tires? I'd be worried about rolling on the high speed turns.....
Race19s is offline
Old 01-31-2015 | 05:58 PM
  #42032
Drew Manzella's Avatar
Originally Posted by wingracer
Yep, 80.285 to be overly exact
Salem's not a bad drive. The track have a website?
https://www.facebook.com/Thembrspeedshop
Drew Manzella is offline
Old 01-31-2015 | 05:59 PM
  #42033
Because that is the size that was on the car I got and they are close to the size I tried down to to start with the last time I raced 12th scale.
Old 01-31-2015 | 07:55 PM
  #42034
DesertRat's Avatar
I would invest in a bigger spur than a 72.
DesertRat is offline
Old 01-31-2015 | 08:42 PM
  #42035
That doesn't really help. Why would I do that? What does that tell me about FDRs/rollouts? As a random example, a 72T spur and 47T pinion gives me the same ratio as an 84T spur and a 55T pinion. So why would I buy a larger spur when the same FDR/rollout can be achieved with the spur I have?
I'm not being a smartass but if you advise something like that, which isn't really an answer to my question then please explain why.
What is the reason for running larger pinions/spurs? I see a lot of people do it now so there must be an advantage but I can't get an answer as to what it is.
Old 01-31-2015 | 10:30 PM
  #42036
DesertRat's Avatar
It is beneficial to your handling to move the motor forward in the pod.
Old 01-31-2015 | 10:33 PM
  #42037
There are a few reasons. First if you change classes to a faster motor you aren't going to be able to move the motor back far enough for a smaller pinion to mesh. Another is gears are more efficient when there are more teeth engaged. And lastly it would have to do with how far forward or rearward the motor is in the pod and how that will affect grip.
InspGadgt is offline
Old 01-31-2015 | 10:34 PM
  #42038
EDWARD2003's Avatar
As you may or may not know, brushless motors are a different breed of motor compared to brushed motors. They produce a considerable amount of torque, and that being said you'll need to covert the motors torque into speed. The only way you can really do this is by running a smaller spur gear (78) and bigger pinion (38) tooth. I've tried running a big spur (96) and (55) pinion, but as your rollout changes, so does your pinion. When the tires get smaller, you're rollout gets smaller, so you'll have to adjust for this with a bigger pinion. I've had situations with a big spur and pinion where my motor couldnt move any further back and wouldn't let me run a larger pinion gear.
Basically, bigger spur and pinion limits the amount of room to play with on you motor mount.
EDWARD2003 is offline
Old 02-01-2015 | 09:47 PM
  #42039
EDWARD2003's Avatar
Hello ya'll.
Below is a setup I've been running as of late.
Associated 0.40 mm front springs
4 shims under the upper arm
Standard track width 165mm
This setup worked well, but I decided to make a few changes to see how the car would handle.
Changes made were:
Increased to 167 mm track width.
1 mm shim between the upper block and bulkhead.
The changes made worked fairly well, handling was great, but it had no mid-corner steering coming off of the straight and onto the high speed sweeping corner.
I suspect, by widening the track width, and the 1 mm shim changed the camber gain quite a bit. Is there any why to keep this suspension setup the way it is and find another way to improve the mid-corner steering? Stiffer springs for example? Steering angle more swept back more? Or should I just go back to the original setup I had before?
Old 02-02-2015 | 07:27 AM
  #42040
Thanks that makes sense.
I ordered 14 (41-54) pinions and 2 other spurs (72, 80, 88) so that should cover me.
Old 02-05-2015 | 02:00 AM
  #42041
Im trying to work out my roll out, My track is fairly tight but has a 40 foot straight. Running 10.5 un boosted.
What would people recommend?
d.k.vmatt is offline
Old 02-05-2015 | 03:23 AM
  #42042
Default Shocks upgrades
Any recommendations optional shocks for VBC lightning 12
Smithkek is offline
Old 02-05-2015 | 06:36 AM
  #42043
When we used to run 10.5 boosted on a 36x50 track I ran around 60mm
jdeadman is offline
Old 02-05-2015 | 12:06 PM
  #42044
Agree with Deadman on the rollout and would add not to set the ratio by the motor temp. Check your timing/gearing sit-up with the clock.
The track isn't big enough for temps to be the guide. More timing/lower ratio or less timing/higher ratio - work out which is fastest by looking at your lap times and 'difference' across the race. HTH
SlowerOne is offline
Old 02-05-2015 | 12:19 PM
  #42045
wingracer's Avatar
team prime of you can find it, CRC Encore if not.
wingracer is offline
