Rev 3
Rev 3 owners,
How do you keep the new larger batteries from moving side to side. Mine move easily and ride up on the side link with any contact. Thanks Dave |
Originally posted by stormperson MX5- I would also seariously think about looking into the SpeedMerchant Rev. 3 Not being serious, attempting to be funny:) E |
with the quad 12 we use a thin piece of foam tape on the batt brace it keeps batt from shifting around!
FiddleFaddle,
A flat file, and a little "fit" time and you will be good, just go slow, and make sure you don't remove to much of the batt slot, so they don't hang below the chassis. |
Originally posted by Fike Stormperson... Again with the Rev. 3 promoting, it's not the best thing since sliced bread ya know....:D :D |
peanut butter... let's not even go there :lol:
YOU WILL ALL SEE THE LIGHT!!!:D ;) lol
As was said before just file/dremel/sand the battery holder, it might also be nessessary to do the same to the chassis itself. But dont do too much, keep on test fitting the batts to check. Also another thing that could cause that, is the nuts/screws that hold in the battery tray. Make sure that they do not hit the battery, if you use any other nut besides the stock non-locking mini 4-40 or any screw that pertrudes higher than the nut you are asking for trouble. I actually dremeld the nut so that the side that faces the batts is sloped just in case (although it might be a little much, lol). |
the one thing i like about the quad 12 i have been running dpowell made the opening for the batt at the perfect size that requires only slight sanding to get rid of the sharp edges and the batteries sit just about flus maybe a hair under the chassis for putting the wieght low as possible!
every other car i have ever had required a lot of sanding and filing. |
where can you oder the quad 12.
Quad12
Originally posted by tc3xlr8er where can you oder the quad 12. For the time being, the Quad12 conversion is only available from me. Send me a PM or e-mail and I'll provide more information. D.P. |
HeY!!!
i have just two qeustions my freind and i are prolly going to get a rc L3 1/12 scale and we're both wondering what would be a good setup to start out w/, and also if you need a special diff to race mod??? in advanced thanks to whom ever will help.:nod: !!! |
anyone knows what the size of the front and rear of Jaco tires out of the box
thanks |
Originally posted by fReShJiVe anyone knows what the size of the front and rear of Jaco tires out of the box thanks Gray rears, 2.10" Purple fronts, 1.94" D.P. |
Originally posted by DPowell Fresh out of the box... Gray rears, 2.10" Purple fronts, 1.94" D.P. |
DPowel: I noticed that you hail from Denver. Is there much 1/12 scale racing there? My sister-in-law lives in Castle Rock. Could be a reason to visit more often....:nod:
| All times are GMT -7. It is currently 03:52 AM. |
