Like Tree2991Likes
1/12 forum
Old 07-26-2012 | 03:57 PM
  #38101
b_recliner's Avatar
In this thread I have a futaba s9650 for sale cheap.
http://www.rctech.net/forum/r-c-item...aba-s9650.html
b_recliner is offline
Old 07-26-2012 | 04:05 PM
  #38102
wingracer's Avatar
Originally Posted by M7H
Don't forget about the Savox SH-1357, once you have used it you will never look back.....
Don't get it if you're running Spektrum.
But then, if you are running 1/12th, you should NOT be running Spektrum
wingracer is offline
Old 07-26-2012 | 04:15 PM
  #38103
cwoods34's Avatar
I'm building up a 1/12 and I currently use Spektrum...... How bad is it gonna be
cwoods34 is offline
Old 07-26-2012 | 04:26 PM
  #38104
wingracer's Avatar
If it's the newer Spektrum stuff, it's not bad but latency is still not as low as I would like. First gen Spektrum, dump it now and upgrade to something better. Don't use Savox servos with it, glitching is a known problem with that combo. Savox and a Tekin with a Spektrum, don't even go to the track, leave it on the shelf. Futaba or JR servo with a Tekin or whatever speedo and you should be good.
Old 07-26-2012 | 05:31 PM
  #38105
Aaronk99's Avatar
Hi guys what would be good gearing combo on a x12 with a 8.5 on a track with a big strait
the xray has the stock spur
Aaronk99 is offline
Old 07-26-2012 | 05:35 PM
  #38106
cwoods34's Avatar
It's a 3-4 year old DX3R.... Not the newer silver version.... I've considered upgrading for this next year, but it's hard to swap something you get so comfortable with
Will the Radiopost system work well? I plan on using an SXX with a Futaba servo.
cwoods34 is offline
Old 07-26-2012 | 06:09 PM
  #38107
As long as you have one of the newer receivers that have the internal capacitors (gen2 and newer) and you don't use the Savox servo it should work fine. I ran the micro receiver with the Tekin RS and the JR servo for a few years before I finally started having problems...most likely due to the antenna wire being damaged.
InspGadgt is offline
Old 07-26-2012 | 07:12 PM
  #38108
T-ROY22's Avatar
does anyone run on asphalt anymore and if so what shores would be run?
T-ROY22 is offline
Old 07-26-2012 | 07:17 PM
  #38109
silvalis's Avatar
KO 951!
silvalis is offline
Old 07-26-2012 | 07:41 PM
  #38110
silvalis's Avatar
55mm?
silvalis is offline
Old 07-26-2012 | 09:08 PM
  #38111
LonnyJ1950's Avatar
We race on asphalt sprayed with soda pop for extra grip. Most popular tires are Contacts, 28, 30 or 32 rears and 32 or 35 fronts. Different cars respond to different set ups.
LonnyJ1950 is offline
Old 07-27-2012 | 09:52 AM
  #38112
chris moore's Avatar
Stay with the pink family, double pink fronts, pink or soft pink rears is a good starting point. If you need more wear you can go to purple fronts, as Lonnie mentioned I've been using the contacts also, 35's front 28 or 30's rears.
chris moore is offline
Old 07-29-2012 | 01:17 AM
  #38113
i want one !
Hopefully it will enter production ...
Originally Posted by DesertRat
For all of those who haven't seen CRC's most recent sharp object prototype...
http://events.redrc.net/wp-content/g...arpercrc-4.jpg
CivicTuning is offline
Old 07-29-2012 | 07:32 AM
  #38114
Car Breaker's Avatar
what servo is that and how does he mount it ?
Car Breaker is offline
Old 07-31-2012 | 09:20 AM
  #38115
CFR's Avatar
CFR
looks like a Sanwa micro servo to me
CFR is offline
