Like Tree2991Likes
1/12 forum
Old 01-10-2012 | 04:30 PM
  #37486
attached guide
jdeadman is offline
Old 01-10-2012 | 04:57 PM
  #37487
Buckaroo's Avatar
Originally Posted by jdeadman
attached guide
Love that guide. Last season (my first in 12th) my travelling copy of it was passed all over the pits!
I found that it applies to 10th WGT as well.
Buckaroo is offline
Old 01-10-2012 | 05:18 PM
  #37488
Thanks a coulple years ago I got tired of hunting around to different places for all of the 1/12th scale info so I put together that
it has served me very well. I also really like the New rc workbench (IPhone app) from the guy who wrote the XXXMain setup giude
Very Nice
jdeadman is offline
Old 01-10-2012 | 08:34 PM
  #37489
bkspeedo's Avatar
Originally Posted by ByteStream
Recently my 1/12 has been "Square'ing up" corners if you know what I mean .. the car enters the corner well and about mid corner the rear looses traction, slides a bit and centers itself on corner exit, resulting in loss of corner-speed.
What is this a sign of? I've been messing around with front and rear track width, camber and tweak and have not found the issue yet .. Anyone have suggestions for this behavior?
I also have a theory that i need to prove out which could cause this phenomenon.
If you run the servo flat it creates a fair amount of bump steer (front tires toeing in when the suspension is compressed). If you turn in a slight bit to hard the car will lean over more and bump steer will increase your steering angle causing the car to over-steer. If you can drive smooth this effect won't be noticed because the car is not leaning over as hard.
This is just a theory but ever since I've gone to flat servo's in both my 12th and WGT I've noticed this happening. The vertical position of the links does not seem to help the bump steer affect.
I can now see why CRC uses the angled servo mounts, it completely removes the bump steer affect. The problem with this design though is controlling ackerman.
bkspeedo is offline
Old 01-10-2012 | 11:45 PM
  #37490
Arahawak's Avatar
Hi 12th gurus..
What is the optimum tires sizes to run on carpet and asphalt??
Would 44mm front and 46mm rear good for both?
Arahawak is offline
Old 01-11-2012 | 07:30 AM
  #37491
Originally Posted by Arahawak
Hi 12th gurus..
There is no optimum size, it all depends on the track, the grip you have and the motor you run.
Generally the slower motor you run the higher tyre you can use.
For good handling on carpet use 43mm rear 41.5mm front as a starting point
Nilezb is offline
Old 01-11-2012 | 09:11 AM
  #37492
bkspeedo's Avatar
Hi 12th gurus..
If your running at a big race starting tires in the 41mm range is good. The problem with starting this small is you won't get very many runs from the front tire.
For club racing start fronts around 43 and rears 44mm.
bkspeedo is offline
Old 01-11-2012 | 11:12 AM
  #37493
For asphalt I would run no less than 45 in the rear and about 1mm less in the front
but it really all depends on what you are doing
Big races with an F tonne of traction then 41 rears are not uncommon
blinky 17.5 club racing 45 mm is not too uncommon
jdeadman is offline
Old 01-11-2012 | 04:18 PM
  #37494
DesertRat's Avatar
Do you guys find that your front tires or rear tires wear out faster?
DesertRat is offline
Old 01-11-2012 | 04:44 PM
  #37495
LonnyJ1950's Avatar
I find my rear tires rarely wear out, they are usually chunked to death. Fronts last a really long time.
LonnyJ1950 is offline
Old 01-11-2012 | 04:46 PM
  #37496
Arahawak's Avatar
Thank you all guys.
At the local club, we run asphalt and the veterans are saying the car would not have enough clearance if the tires are smaller than 52mm..
is that possible?
Arahawak is offline
Old 01-11-2012 | 04:56 PM
  #37497
RedBullFiXX's Avatar
For club racing, I start with Yellow/Black @ 45R, 43F
They wear down to 41.5 & 39.5 after about 10 runs in Blinky.
At that point, I clean them up on the truer, and set them aside for the iic @ Vegas, where they are perfect for another few runs
RedBullFiXX is offline
Old 01-11-2012 | 05:22 PM
  #37498
I tend to wear my fronts almost down to the plastic. Setting the ride height when they get so low can be a bit tricky.
AreCee is offline
Old 01-11-2012 | 05:37 PM
  #37499
The only set I've had long enough (Magenta Fr/Pink Re) to wear out started at 44/46 and are now 41.5/42.0 so I'm thinking the rears wear a bit faster on my car. The fronts look like they've been chewed on around the outer edges which happened in the last few runs, rears still look great.
linkless is offline
Old 01-11-2012 | 05:50 PM
  #37500
chris moore's Avatar
Thank you all guys.
is that possible?
Well its possible if the asphalt is in very rough shape, and if it is that rough running 1/12 is a real challange.
chris moore is offline
