Like Tree2991Likes
1/12 forum
Old 10-07-2011 | 01:40 AM
  #36646
dontfeelcold's Avatar
Just in process of balancing my 1/12 for asphalt.
I have 45f/55r wight distribution. Is this to rear heavy to beging with?
dontfeelcold is offline
Old 10-07-2011 | 05:32 AM
  #36647
TrevCoult's Avatar
Originally Posted by JamesL_71
Yep. Turns out CRC is released a "shorty" 1S lipo.
And it is a new car:
http://www.rc50.com/modules.php?name...bum=67&pos=278
Yeah, a few more things different than I first noticed.
Trev
TrevCoult is offline
Old 10-07-2011 | 10:16 AM
  #36648
Infinite 12th's Avatar
How come no Hot bodies and schmacher 12th?
Infinite 12th is offline
Old 10-07-2011 | 10:20 AM
  #36649
defcone's Avatar
Trev
That's some serious pinion action going on.
defcone is offline
Old 10-07-2011 | 11:42 AM
  #36650
Originally Posted by YR4Dude
Xceed foams has always been made by Jaco. I know this from 1/10th nitro as all the Xceed 1/10 foams are made by Jaco so it would be obvious the 1/12 is the same. However, Jaco claims that their tires are pre-trued and ready to run straight out of the box. Not sure if that is true with the Xceed. Try a set and see. Worst case all you need to do is put them on a truer. If not then you'll save a few pennies because they're slightly less than the Jaco branded ones.
Xceed foams are not made by Jaco and never have been. Xceed make 8th tyres, and their compounds are based on that. They aren't badly out from the box, but a true on the truer is needed to make sure that you have the same diameter side to side, and true tyres.
They're good tyres. They don't chunk and split as easily as Jaco, and they give excellent grip. However, they are probably 0.1/0.2s per lap slower than Jaco, but much easier to drive. I find I get a better time over eight minutes from Xceed than Jaco because I am not always on the edge of my talent! I am a C/D finalist at UK Nationals, and have been making some progress up the lists using Xceed because they are more consistent to drive. HTH
Originally Posted by bucketboy
Anyway my questions are:-
what is best, a high rev or high torque motor for 10.5 blinky
lap times in the second half of run were 0.4sec slower than at the start, is that due to addative, batteries or the motor getting hot (60deg)
Bb
What is best is the motor with the most power. Power is torque x revs, so a motor with revs can produce the same power as a motor with torque. It doesn't matter which one you have, as the speed you get depends totally on gearing for the track layout. I find GM motors very tolerant of high heat so you can gear them up a bit and find a bot more top speed for an open track. However, for a tighter track, you have to gear them down, but then they will accept more timing. HTH
SlowerOne is offline
Old 10-07-2011 | 12:03 PM
  #36651
Hot Bodies is testing prototype, by Ben Cosgrove
fotko is offline
Old 10-07-2011 | 12:51 PM
  #36652
YR4Dude's Avatar
I'm not aware that Schumacher ever even had a 1/12th car.
YR4Dude is offline
Old 10-07-2011 | 01:01 PM
  #36653
Joost K.'s Avatar
Yes they did... But you have to go way back in the history of 12th scale...
The Schumacher "C" car...
Joost K. is offline
  #36654
TrevCoult's Avatar
I raced Schumacher 12th scales back in the early 1980s. They have considered it a few times since but the last I heard they had decided they would not make enough money for it to be viable.
Ben was testing a Hot Bodies prototype a while ago but I've not heard anything about it for a while.
Trev
Old 10-07-2011 | 01:14 PM
  #36655
Cecil Schumacher built his business on 12th cars, starting back in 1981. First it was a lexan car (here) the XL, and then the C Car (here) bith of which were very successful in Europe
Cecil Schumacher invented the ball differential in about 1980, and although it said 'Patent Pending' on the parts, he never did get a patent. Cecil was a gearbox engineer, and he used a design from a gear checking machine as the basis for his design. IT is Cecil's original design that has been copied by everyone else. HTH
Old 10-07-2011 | 01:23 PM
  #36656
TrevCoult's Avatar
Yep, I had the XL. That is a very well preserved one, though it's a later one as it has the cut out in the bottom of the chassis near the front. The early ones didn't have that. I've never been able to find a photo of the original stick pack version of the C Car, which is the one I had.
Trev
Old 10-07-2011 | 01:38 PM
  #36657
YR4Dude's Avatar
Thanks, you guys on the other side of the pond are up quite late tonight.
YR4Dude is offline
Old 10-07-2011 | 02:08 PM
  #36658
wingracer's Avatar
Sorry, but that is absolutely and completely wrong. Xceed has had several different tire lines including Jaco made ones. See this page:
http://ashfordhobby.com/detail.aspx?ID=6846
In addition to those, they have also had Italian made and Japanese made lines.
wingracer is offline
Old 10-07-2011 | 03:45 PM
  #36659
Whatever happened with those Gecko tires? I liked the idea of a seamless tire but they seem to have disappeared.
InspGadgt is offline
Old 10-07-2011 | 05:22 PM
  #36660
Here are two videos that show the Schumacher guy talking about 12th scale
http://video.google.com/videoplay?do...94645495&hl=en
http://video.google.com/videoplay?do...29884299&hl=en
