Like Tree2991Likes
1/12 forum
Old 02-24-2011 | 06:09 AM
  #35521
Pattojnr's Avatar
Originally Posted by BBSpence
The last two numbers of the part number is the shore rating...
front magenta 2732
rear magenta 2932
rear white 2825
rear pink 2930
ok i got that bit, but why the 8-9 change ? same size ? just go by the shore rating ? cheers.
Pattojnr is offline
Old 02-24-2011 | 06:12 AM
  #35522
BBSpence's Avatar
Same size, but different type of rubber. Both the Yellow and Pink rears are 30; can't have the same part # for two different tires.
BBSpence is offline
Old 02-24-2011 | 06:19 AM
  #35523
Originally Posted by theisgroup
a wondering steering servo is one of the biggest thing that deter racers from this class. it is soo important that the servo is acurate, that it makes the cars seam tweaked. i have seen many people shy away from the class because their cars just don't work well and it is usually a servo or servo saver.
What specs make for a good 1/12 servo? Torque and speed, specifically.
mahamoti is offline
Old 02-24-2011 | 06:25 AM
  #35524
theisgroup's Avatar
ko 951
theisgroup is offline
Old 02-24-2011 | 07:37 AM
  #35525
wingracer's Avatar
It's not about specs, it's about accuracy and centering. I've seen servos with great specs that wander all over and I have seen servos with low specs do a good job.
wingracer is offline
Old 02-24-2011 | 08:01 AM
  #35526
So, recommendations for a digital metal gear servo that you've seen do a good job?
mahamoti is offline
Old 02-24-2011 | 08:09 AM
  #35527
HarryLeach's Avatar
Futaba 9650
or the KO 951, which I really like.
HarryLeach is offline
Old 02-24-2011 | 08:44 AM
  #35528
303slowdown's Avatar
best servo jr 3650
303slowdown is offline
Old 02-24-2011 | 09:29 AM
  #35529
wingracer's Avatar
See below in red:
Originally Posted by HarryLeach
Futaba 9650 My favorite
or the KO 951, which I really like. Never tried it but I hear good things
Originally Posted by 303slowdown
best servo jr 3650 In my car now and doing a great job
Avoid Hitec and Airtronics for this application.
Old 02-24-2011 | 08:25 PM
  #35530
CypressMidWest's Avatar
The 9650 doesn't have metal gears. It makes no difference, as it is a KILLER 12th scale servo. I have two seasons on mine, still centers perfectly, and is more than strong and fast enough. I have in the past, used the JR3650, and the KO 951.
My current set-up utilizes a 2s lipo rx pack. I find the lighter and slightly slower Futaba to suit my driving and car set-up better than the KO. I haven't tried a 3650 on 2s power, but I know others that have and say it works very nicely.
These are the ONLY three currently available servos I'd consider putting in a 12th scale car.
CypressMidWest is offline
Old 02-24-2011 | 08:35 PM
  #35531
Chubba's Avatar
Currently have a Futaba 9650 in my R12 and it is awesome! drives so straight and the feeling is great!
Chubba is offline
Old 02-25-2011 | 06:11 AM
  #35532
Thanks for all the replies; I'll definitely pick up one of the three mentioned here.
mahamoti is offline
Old 02-25-2011 | 06:18 AM
  #35533
avs's Avatar
avs
HKS makes a metal gear servo that is physically identical to the futaba 9650. the 9650 with these replacement gears is popular for cyclic control on 500 size helicopters.
avs is offline
Old 02-25-2011 | 06:23 AM
  #35534
wingracer's Avatar
Interesting but the Kimbrough servo savers we almost all use are so soft that I have never seen a 1/12th break a servo gear. Burn some up yes but never break.
I actually wish they would make a stiffer one.
Old 02-25-2011 | 06:30 AM
  #35535
theisgroup's Avatar
run the medium servo saver. alot have gone to the medium because it seams to hold better and last longer
