Like Tree2991Likes
1/12 forum
Old 01-18-2011 | 07:25 PM
  #35326
Team Speedy's Avatar
Originally Posted by t4m1y4niac
is it possible to upgrade my 12R5 to 12R5.1??
Give this a go, should be all the parts you should need to go from a 12r5 to a 12r5.1.
  • 4688 upper pod plate
  • 8511 lower pod plate
  • 8536 motor mount
  • 8537 left bulkhead
  • 4687 motor mount standoff
  • 4608 diff hub brushless
  • 4609 thrust cone brushless
On a side note I look forward to trying those TRC Primes this coming weekend. I'll post my feedback after this weekend as my local hobby shop received an shipment this past week.
Team Speedy is offline
Old 01-18-2011 | 08:24 PM
  #35327
Originally Posted by wingracer
Get the yokomo's and dye them.
I thought about doing that...the Yokomo's rim off set is very extreme and would really need a Yokomo axle to be fitted as well.
InspGadgt is offline
Old 01-18-2011 | 08:26 PM
  #35328
Just ordered some of the TRC tires for the race at the end of the month We'll see how good they work in a couple of weeks.
Old 01-18-2011 | 09:21 PM
  #35329
t4m1y4niac's Avatar
  • 8536 motor mount
thanks a lot...i'll find them.
t4m1y4niac is offline
Old 01-19-2011 | 08:02 AM
  #35330
spring71's Avatar
Smile
2011 1st TQ Pan Car Grand Prix is up this Sunday.
Track will be open at 9am, Race will start 12pm.
We will have Trophies for the winners and Raffles for every racers.
Pre-Signup racers will get one more raffle ticket, click here for pre-signup.
spring71 is offline
Old 01-19-2011 | 02:16 PM
  #35331
Mark506's Avatar
The rears have a pretty poor designed webing. Very flexiable, I wouldn't trust them. I would think they would provide a more resilient form than the CRC rim though at times. The fronts aren't as bad (there front tires )
Mark506 is offline
Old 01-19-2011 | 03:18 PM
  #35332
The webbing looks the same as the CRC rim...maybe the plastic is different as the CRC has very little flex...but look at the Jaco rims...they have quite a bit of flex so maybe that's a good thing.
Old 01-19-2011 | 03:46 PM
  #35333
The Yokomo rear rims have a lot of flex in them... and guess who keeps winning the worlds
PHI/BMI racer is offline
Old 01-19-2011 | 03:53 PM
  #35334
Yup...I wanted to try the Yokomos as I really like the way the rim looks...but I didn't want to have to change out the axle.
Old 01-19-2011 | 08:56 PM
  #35335
BrodieMan's Avatar
Default 1/12 on pavement??
I am organizing a club for this summer, looks like we will be running on a specialized Soap Box Derby track. It's basically a two lane road that's in pristine condition. I plan on pushing RCGT but was curious if 1/12 would run well on regular asphalt??
BrodieMan is offline
Old 01-20-2011 | 12:23 AM
  #35336
CypressMidWest's Avatar
Wow!! One race every two years!!! And hey, it only takes MASAMI to be the tire bitch/pit strategist to make it happen, You're right, totally superior performance....
Give me week in/week out performance every time. If they hadn't started the worlds with weak tire additive things might have been different.
I'll take a proven performer everytime, and that's CRC high rollers. IIC, Snowbirds, and Cleveland, ya know, the REAL Carpet races......
CypressMidWest is offline
Old 01-20-2011 | 12:48 AM
  #35337
Not taking anything away from any other tire brand, but Masami has been using them for years and now his mini me version They always have an edge with those tires, mostly on asphalt though, carpet is another story.
Anyway we were talking about the rims, not the tires... I would say Yokomo tires on any other rim would also be great... It's the rubber that makes the biggest difference....
AGAIN NOT SAYING CRC or any other brand is not good!!!! I have used different brands under different conditions and they all have an advantage somewhere...
Old 01-20-2011 | 04:28 PM
  #35338
kerry's Avatar
Default new crc pan car
a few months ago i thought i read that crc were working on a new 1/12th. any news or update on a expected release date
any information would help, thinking about trying the new TOP pan car and would like to compare
thanks guys
kerry is offline
Old 01-20-2011 | 07:35 PM
  #35339
chris moore's Avatar
Yes if the asphalt is smooth enough it can be done very easily. Its best if you can lay down some type of sugar water or soda to help with the grip.
chris moore is offline
Old 01-21-2011 | 05:13 PM
  #35340
t4m1y4niac's Avatar
i'm new in 12th scale, planning to use LRP SXX TC Spec speedo..should i use extra battery for receiver?
can give me info what brand and type the battery is?
thanks.
