Like Tree2991Likes
1/12 forum
Old 10-15-2010 | 05:21 AM
  #34921
Yokomo_Ant3's Avatar
Originally Posted by mangoman
Ahh i remember he was testing a car (T-Bar with a LiPo pack mounted up the side of it) at last years nationals but i thought he didnt end up running the meet.
I think he was testing a Yokomo 12L3 and then someone lent him a 12R5 i think
Yokomo_Ant3 is offline
Old 10-15-2010 | 05:33 AM
  #34922
=FLIP='s Avatar
Originally Posted by Dragonfire
Its funny that alot of.you guys keep saying that. Here in Oz almost every 12th is running something else to avoid the problems they were having with the Tekin. Currently BD's and SXX rule and the new hobbywing is growing in popularity as well. Its not that any of them are proven to be faster its more that the difference is not worth talking about but the Tekin has the most problems. If you want to go by performance then here in Oz the BD has destroyed everything and tekin is lucky to make an A final.
i have no problem with tekin in 12th infact it is fast and has massive runtime and troy stop the speedy dick measuring competition .all speedys are good now
bd is good ,lrp ver2 is good, tekin is good, hobbywing is good,novak kinetic 1s is good.
i think 12th comes down to driving. you could probably whip everyone with a 10.5 in ya car and a bar of soap for a speed controller.
=FLIP= is offline
Old 10-15-2010 | 05:37 AM
  #34923
Scottrik's Avatar
My Irish Spring w/ v.222 suds-ware is faster. Pour a little bottled water on it, rub it a little and LOOK OUT!!
Only problem is I only get 2-3 race weekends and it's down to a little sliver that will never go away, but doesn't perform (suds up) as well so I have to break out a fresh bar.
Scottrik is offline
Old 10-15-2010 | 11:55 AM
  #34924
I have found that if you use sparkling water, you get larger bubbles.
Crashby is offline
Old 10-15-2010 | 12:10 PM
  #34925
Default tires
I've had good luck with the CRC greylow, They don't chunk as easily as yellow. Is the Parma orange the equivalent (the shores match)? Does Jaco make an equivalent that is not on their website? Didn't Jaco come out with some new compounds a while back?
Tuner EM is offline
Old 10-15-2010 | 01:23 PM
  #34926
JayBee's Avatar
You can also try BSR Gray-Whites. They are on the same wheel as CRC
JayBee is offline
Old 10-15-2010 | 01:29 PM
  #34927
TrevCoult's Avatar
Parma Orange is the equivalent to the CRC Gray Low.
Jaco Orange is the same as Parma, Parma tires are made by Jaco, the wheel color is the only difference.
Trev
TrevCoult is offline
Old 10-15-2010 | 01:37 PM
  #34928
They all get their foam from Jaco anyway.
peter_robinson is offline
Old 10-15-2010 | 01:47 PM
  #34929
TrevCoult's Avatar
CRC do NOT get their foam from Jaco. Frank will confirm.
Trev
Old 10-15-2010 | 02:07 PM
  #34930
JayBee's Avatar
I think John from BSR does Franks (CRC) foams....
JayBee is offline
Old 10-15-2010 | 02:08 PM
  #34931
protc3's Avatar
Dont they go through BSR?
protc3 is offline
Old 10-15-2010 | 02:30 PM
  #34932
avs's Avatar
avs
fyi, bsr is shipping their own wheel now. it is the 3 hole 'velocity' rim like on their website
avs is offline
Old 10-15-2010 | 02:32 PM
  #34933
Those are the old rims. New batches are on the 38mm rims from CRC.
Serzoni is offline
Old 10-15-2010 | 02:41 PM
  #34934
JayBee's Avatar
NOPE!!
EXACTLY!! But I think John should've put his on BLACK CRC 38mm rims. That would be awesome
JayBee is offline
Old 10-15-2010 | 02:50 PM
  #34935
whynot's Avatar
EXACTLY!! But I think John should've put his on BLACK CRC 38mm rims. That would be awesome[/QUOTE]
+1
whynot is offline
