Like Tree2991Likes
1/12 forum
Old 09-24-2010 | 03:23 PM
  #34636
thanks!
artoftatt2 is offline
Old 09-24-2010 | 03:25 PM
  #34637
wingracer's Avatar
Originally Posted by artoftatt2
i wanna switch to the longer front arms but cant find theme anywhere??
any help would be aprecciated thanks!
Ashford has the brace:
http://ashfordhobby.com/detail.aspx?ID=5911
And the arms:
http://ashfordhobby.com/detail.aspx?ID=7119
wingracer is offline
Old 09-24-2010 | 05:45 PM
  #34638
wingman2's Avatar
Originally Posted by EVILGRAFX
He's talking timing boost and turbo boost. The first number before the slash is timing boost and the second number is turbo boost.
Keep an eye on the Tekin RS thread and you'll get some good info on the RS.
Hi mate, have you got the chance to run the 208 software in your 12th car yet?? Going over to Deb's tomorrow so maybe have a chat then, ok?! Cheers bud.
wingman2 is offline
Old 09-24-2010 | 06:07 PM
  #34639
hanulec's Avatar
R/C Tech Elite Member
Originally Posted by safaridog
Hanulec thanks for the answers. I'm bit confused when you mention 50/8 45/8
The 50 stands for timing, and 8 stands for Turbo -- both available in sensored mode. I'd also recommend running 30 push control, throttle profile 5 and Turbo ramp 2. I don't recommend selecting the 1s check box.
hanulec is offline
Old 09-24-2010 | 06:12 PM
  #34640
avs's Avatar
avs
Originally Posted by wingracer
hey! cut that out. Ashford always has stock for whatever i need.
if you go telling people, then where is that going to leave me?
avs is offline
Old 09-24-2010 | 06:26 PM
  #34641
BCbud's Avatar
Good day!
Why would you not select the 1 cell box?
BCbud is offline
Old 09-24-2010 | 06:28 PM
  #34642
wingracer's Avatar
Robert will still be in business to continue selling you what you need.
Old 09-24-2010 | 07:03 PM
  #34643
Chris,
I won't be at the track tomorrow, I have a 5K run in the morning and a wedding in the afternoon. I have not run 208 in a 1/12th yet, I've only run touring since it warmed up. I do have a new 1/12th on the way and hope to get some track time before too long. If you figure anything out, you'll be ahead of me and I'll be the one asking questions.
As far as 208, in touring I haven't noticed much difference, it just seems a little smoother.
EVILGRAFX is offline
Old 09-24-2010 | 07:10 PM
  #34644
hanulec's Avatar
Originally Posted by BCbud
Good day!
Try it yourself ... all settings come thru testing.
hanulec is offline
Old 09-24-2010 | 07:15 PM
  #34645
wingman2's Avatar
Chris,
No prob mate, I noticed you posted something on the CH12 page and all, that's a nice bit of kit! Cheers buddy.
wingman2 is offline
Old 09-24-2010 | 09:26 PM
  #34646
Default Front tire coneing... add or subtract camber?
Both my front tires started to cone after 1 run. The inside of the both front tires are smaller than the outside of the tires. (ie inside wears faster than outside)
So, should I add more camber or less camber in this situation? Many thanks!
hardmankam is offline
Old 09-24-2010 | 09:42 PM
  #34647
A slight bit of coning all across the front in the same direction is normal as there will always be 1 corner more to one direction than the other. However both coning with the inside smaller than the outside is most likely too much camber so you will likely need to take some out. What did you set it at?
InspGadgt is offline
Old 09-24-2010 | 10:10 PM
  #34648
as i dont have the proper 1/12 setup equipment, i can only 'eyeball' or estimate the camber setting. I set at about -1.5 degree on both tires.
As you suggest, maybe I will remove some camber and try again.
thank you!
Old 09-25-2010 | 05:58 AM
  #34649
safaridog's Avatar
Thanks again
safaridog is offline
Old 09-25-2010 | 08:26 AM
  #34650
Well after reading a lot of the pages on this topic i have bought a Corally 12SL
I decided to buy a voltage booster to un my Tekin Rs and my reciever
What speed servo should I look for ?? is 0.12 to 45 degrees fast enough at 6v
sidecarphil1 is offline
