Like Tree2991Likes
1/12 forum
Old 09-15-2010 | 01:30 PM
  #34501
At IIC only ESC timing was limited. We were allowed to run any motor timing we needed to make the motor competitive.
Given the way the trend is going I think we will eventually see a fixed timing motor and rule. But until all the motors are timed the same it isn't something that should be enforced unless someone can figure out exactly what timing mark on each motor is the same.
InspGadgt is offline
Old 09-15-2010 | 02:07 PM
  #34502
RedBullFiXX's Avatar
I would think that no boost would be enough control to be fair for club racing.
All motors have different specs of physical timing.
No need to bring on unnecessary restrictions that bring about other inequities in pace.
RedBullFiXX is offline
Old 09-15-2010 | 03:58 PM
  #34503
odpurple's Avatar
Originally Posted by one-nil
I have a 12L3 with the 4 cell chassis (broke the original 6 cell one ) how do I convert that for lipo? Ideally I just want a single one that runs across like stick pack but will that be possible or will I need to stick to the saddle pack conif? Thanks.
Get the Speedzone 3.7v saddle pack. It will drop right in to the L3 and its an excellent battery. Placing a stick pack on one side and the electronics on the other works ok but you have to add way to much weight on the elctronics side to balance the car. I've used the Speedzone saddle pack in the OD12 and it fit perfectly with no modifications. Performance was better than with the battery hung on one side
odpurple is offline
Old 09-15-2010 | 04:25 PM
  #34504
DPowell's Avatar
If we could convince them to produce that pack with bullet connectors instead of Deans plugs it would be even better.
DPowell is offline
Old 09-15-2010 | 04:54 PM
  #34505
Dread Pirate's Avatar
I ran this battery pack on my L3 at IIC last week; I was the only 1/12th scale there running a t-plate car. I think this pack along with the new ESC's with the booster built in can really give some life back into the older cars.
I thought it performed great. I came in 2nd in the D-main so while that isn't a ringing endorsement, driving wise I was very happy with handling of the car.
Yes, bullet connectors would be better, but I was really glad to have this kind of pack available.
Dread Pirate is offline
Old 09-15-2010 | 05:20 PM
  #34506
wingracer's Avatar
Still wouldn't matter. How do you know 0 really is 0? Even if the manufacturer says it's 0 and the endbell is on the zero mark, that doesn't mean it really is 0. I know of no simple way to determine EXACTLY when the sensor trips at speed so there is no way to enforce this.
wingracer is offline
Old 09-15-2010 | 07:32 PM
  #34507
avs's Avatar
avs
always the voice of reason, Dave.
although the 'idea' of a stock class with fixed motor specs might seem nice, it would seem that timing is not entirely fixed by geometry, if one speedo ran a little more sensitve than another, it might 'sense' the rotor position earlier and get a little lead.
the way i understand brushless motors today, it makes the most sense to let every motor maker set its optimum fixed timing for its can, rotor, sensor set, and go. otherwise there will need to be a whole net set of motor spec's that demand the sensor trigger sensitivity be equal to a standard.
avs is offline
Old 09-15-2010 | 07:42 PM
  #34508
avs's Avatar
avs
Ha! i started pontificating and forgot to ask the question!
with the fixed ESCtiming class, what sort of motor timing and rollout did people end up with in the 17.5 1/12 class?
avs is offline
Old 09-15-2010 | 07:52 PM
  #34509
spring71's Avatar
Smile
at IIC they had a limited 17.5 class? did it restrict sensor position on the motor or only ESC settings?
it would seem that a 'locked' motor rule should rule out some motors with some fixed timing?
Originally Posted by HB Moose
Adding it to my schedule. But no motor timing in the limited 17.5 class? I'll need even bigger pinions.
Since just about every 17.5 motor has a different timing value at the 0 mark you should rethink the timing on the motor part...
Hello guys,
Thanks for the advice.
I took out the motor restriction.
1/12 17.5 cirtix spec class is added, and made 17.5 open class.
spring71 is offline
Old 09-15-2010 | 08:22 PM
  #34510
Cool...good to know organizers listen when things make sense
Old 09-15-2010 | 08:23 PM
  #34511
It varied a lot depending on the motor. With my Duo 2 motor I ran it timed 1 tick from max geared at 54/72 with a 42mm tire. With the LRP I had the 2 hole timing geared at 62/72 I think it was. Might have been 64.
Old 09-15-2010 | 10:29 PM
  #34512
JayBee's Avatar
Anybody a LRP X12 13.5? Have you played around with the endbell timing? We're running out here with no boost (0 timing on the esc). Rollout is between 85-88mm between all drivers; just wanted a bit more infield grunt. I'm running a LRP SXX v.2 btw....
Thanks guys
JayBee is offline
Old 09-16-2010 | 02:02 AM
  #34513
edit: posts here and here.
kjoer is offline
Old 09-16-2010 | 03:18 AM
  #34514
How are you ?
Like this
http://www.facebook.com/photo.php?pi...&id=1374897830
Alf :-)
alf.skaar is offline
Old 09-16-2010 | 03:29 AM
  #34515
Hope you got back home safe.
Nice to meet you.
What about Hand out motor for 17.5
Alf :-)
