Originally Posted by JayL
(Post 7045295)
Looking for rollout help:
track: Speedworld 100+straight Asphalt esc LRP spx batt: TP 40c 1s motor Duo1 13.5 LiFe recv pack, not a booster Thanks for any help! The real trick was to use profile 7, not 8.....:weird: If you're runnin' against Tekins........enjoy the scenery........:lol: tail lights, theirs |
Servos???
I have been looking at 2 different servos. Airtronics 94761 & Futata 9650 for my new Gen XL. Need advice on which would be better to use.
1/12 Scale European Sports Car Championship
Radio Controlled Model Car Racing at it's very best. 5 – 7th March, Hinckley Leisure Centre Coventry Road, Hinckley, LE10 0JR Friday 5th – Practice & Qualification Saturday 6th - Qualification Sunday 7th - Finals. The event features 1/12 scale LMP prototype style cars, driven by the very best RC racers in Europe (The top 120 drivers out of the 30,000 who race) The cars are electrically powered and compete in10 car 8 minute races, qualification is by laps completed in that time and the finals are decided from a grid start by racing for position. Performance is outstanding 0-30 in well under a second, 3g plus lateral G, lap times in the order of 12 seconds. Plus of course all this happens indoors in the warm! Doors open at 9am each day, with the last race at around 6pm, admission is free. Special Media Day, Friday 5th March, Experts on hand to take you through our sport, guided pit tours including behind the scenes of a fully computerised race control facility ( 120 drivers competing in 140+ races all digitally timed ) plus analysis and technical explanations of the cars. Further Details from:- Jim Spencer – 07976 623772, [email protected] www.ec2010.org www.brca.org |
Originally Posted by svines1972
(Post 7055838)
(Post 7055838)
Trev |
Black art bodies
Hey anyone know where to get Black Art bodies besides CRC? they only have two and i am looking for the new one called Bomb'r
Wire thickness for my ESC?
I have just purchased a slightly used LRP SXX Comp ESC, but there are no motor wires on it.
What thickness should i use? 14AWG or 16AWG? I run a LRP Vector X12 5,5T motor and 1s Lipo. Is 16AWG thick enough? And are there anyone who will post a picture of there car with a RX battery? I need some ideas where to place it on my Associated 12R5.1 |
Originally Posted by Frank-DK
(Post 7057081)
What thickness should i use? 14AWG or 16AWG? I run a LRP Vector X12 5,5T motor and 1s Lipo. Is 16AWG thick enough? And are there anyone who will post a picture of there car with a RX battery? I need some ideas where to place it on my Associated 12R5.1 Nice size, light weight, and cheap priced. |
Its been awhile since I've heard much talk of people running unregulated receiver packs. For those who have, how are the servos holding up? I'm running a Futaba and just haven't heard much about it.
12th scale wire ??
3 Attachment(s)
I have a couple rolls of Race Prep wire from back in the early 90's that have never been used ... it seems to be too thin for 14 gauge, and I had a tip that the 12 scale guys may run 16-18 gauge wire if it is flexible, which this is. There are a little over 9' of both both orange and black (18' total), and I also have about 2' of good quality battery braid as well .. drop me a note if you have a use for them.
Servo Specs?
I'm new to 1/12th scale pan cars, and I have a question regarding servo needs for this class. I did a search on this thread on servo's, but all I found was REALLY old messages on the subject.
The manual says that a "micro" servo is recommended, but I'm a little leery of what each manufacturer might consider "Micro". I'm looking at a Hitec HSG - 5084MG Digital servo with these specs - Motor type: 3 Pole Bearing type: Metal Gear Speed: 0.07 @ 6v Torque: 26oz @ 6v, or 1.9kg.cm size: 29mm x 13mm x 30mm (34mm mount points-which appear to fit the left side) Is that enough torque? This sure is a small little burger—I"m used to 1/10th scale servo's. Any help is much appreciated. ...Ron |
Do yourself a favor and get a Futaba 9560.
Originally Posted by ronb
(Post 7058054)
The manual says that a "micro" servo is recommended, but I'm a little leery of what each manufacturer might consider "Micro". I'm looking at a Hitec HSG - 5084MG Digital servo with these specs - Motor type: 3 Pole Bearing type: Metal Gear Speed: 0.07 @ 6v Torque: 26oz @ 6v, or 1.9kg.cm size: 29mm x 13mm x 30mm (34mm mount points-which appear to fit the left side) Is that enough torque? This sure is a small little burger—I"m used to 1/10th scale servo's. Any help is much appreciated. ...Ron Hitec HSG - 5084MG, will fit in a 12th scale, the sizing is a little smaller than JR Z3650 Depending on what car you are running JR Z3650 is my choice. Spend a little more and get JR Z3650. Found this being metal gear also faster over the Futaba S9650, this is just personal preference however. It don't fit in the RC12 due to the servo being mounted to the deck, can be done via servo tape just make sure you warm up the tape before hand to get a good seal. CRC, Xray and Serpent 120 all have servo post like TC's.. so can run something smaller. Hope this helps Alex |
Servo suggestion
Thanks Me_MrTyson,
I'll look into the JR servo. I have a XRay XII Link, with the Novak Havoc 1S ESC/Novak 13.5SS Pro brushless motor, Spektrum SR3500 micro receiver, and a 1S lipo. This is looking to be tons of fun!!! ...Ron |
mod motor
Hey guys what mod motor do you recomend using in 12th mod?
I am thinking of getting a 4.5T-6.5T that got a smooth acc curve. Thanks |
| All times are GMT -7. It is currently 04:00 AM. |
