-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Billy Kelly 10-26-2020 02:10 PM
Originally Posted by SchumacherGT12 (Post 15707322)
Thanks for the reply, I am aware that setup would be fat better. I still need to know whether or not those 4 cell packs will fit or not?
This setup is for a younger rookie driver so speed is not important at this time.
Honestly, I doubt many have even tried a nimh battery in anything current. It’s easy to turn the throttle down off the controller for a younger driver then to use batteries to limit power.
terry.sc 10-26-2020 04:25 PM
[QUOTE=SchumacherGT12;15707305]Hello I am wondering if a 4 Cell EP Nimh battery with the dimensions of 93.5x46x24mm fit in the Schumacher Atom 2 GT12 chassis?[/QUOTE]
Yes, it should fit in no problem.
The shorty lipo pack is designed around the size of a 4 cell nimh pack, so any car designed for a shorty lipo should fit a 4 cell nimh pack
HarryLeach 10-26-2020 04:41 PM
1s lipos these days typically have a height of 19mm or less. Add in that any chassis made since 2010ish and newer doesn't have cell cutouts, and a 4 cell NiMh pack isn't likely to fit.
I would expect the center shock on most cars to be the biggest interference.
Batteries keep coming down in price while improving in performance, so the best bet is to use a battery the car was built to use and slow it down with motor choice and throttle end points, if further slowing is needed.
Goof 10-26-2020 05:52 PM
Evening 1/12 forum can some 1 tell me the names of all the 12 scale races matter that matter for the pro ? and what should I look for most in a esc for a motor with no timing for 1s 12th scale
Thank u
gubbs3 10-27-2020 07:25 AM
Thank u
I might get lit up for answering this loaded question! If your talking the US...
Chronologically each season:
Vegas
Halloween Champs
USIC
Hudy Race
Snowbirds
ROAR Nats
Can-Nats
MHIC
Other notables:
NY Champs@360
MIC @GenesisRC
and Worlds! US 2022
simple 10-27-2020 07:36 AM
When you are Professional....every race matters.
Muddbutt69 10-27-2020 10:34 PM
When you are race... every professional matters.
Bsthetech 10-28-2020 06:43 AM
My car is underweight by 6 grams. Where is the best place to add the weight on a 1/12 pan car?
gubbs3 10-28-2020 07:02 AM
Remove the pod and use the weight to balance the chassis.
simple 10-30-2020 05:46 AM
Source of the 4WD belt driven chassis shown above...:.....Remember Hirobo from back in the 80's??
Hirobo Prototype RC 1/12th scale pan car
BullFrog 10-30-2020 09:49 AM
I also remember there 4 wheel drive off road car. had alst of fun with it back in the day.
Muddbutt69 10-31-2020 03:29 PM
Do tires wear more using a spool? I raced today and noticed my tires were a lil smaller than I'm used to finishing the day.
hanulec 10-31-2020 03:38 PM
The rears somewhat cone due to a spool
DesertRat 11-02-2020 09:41 AM
When truing tires, cutting a 45 degree straight chamfer bevel into the rear tire may help reduce the cone-shape wear. It also seemed to give a better driving feel than a rounded edge, as it makes it harder for the car to "roll up" on the edge, which can cause lifting of the inside rear or even traction roll.
I always had a gift for burning off 1/12 tires.
Muddbutt69 11-02-2020 07:41 PM
Roll up and traction roll even with Cleveland size tires? I'm not being smart I'm just new to 1/12 scale.
