Like Tree2991Likes
1/12 forum
Old 01-16-2010 | 09:52 AM
  #33271
whynot's Avatar
Originally Posted by JustMe2
The complete screw kit from CRC is anodized red and only like $16.
I was looking for some that are stronger than the stock screws, thanks for the reply.I was checking out rcscrewz, are these what people are using?
mike
whynot is offline
Old 01-16-2010 | 09:53 AM
  #33272
Originally Posted by Clegg
Yeh Chuck above got his from a large order I placed to CS directly a few months ago. Shipping was more expensive than the glue! So if you are going to order some... make sure you order a ton of it. Also since their site is not at all in English, you need to practice up on your German in order even complete the order process. (as the paypal site it sends you to is in German also)
I asked them of their plans to ship domesticly, and they said "Nope".
From all the CAs I tested on sidewalls... this stuff is the best.
So does that mean you have extra you can sell to the rest of us?
JustMe2 is offline
Old 01-16-2010 | 09:58 AM
  #33273
mike
I wouldn't suggest these guys. I bought a car for my son that was equipped with their screw kit. The same size screws would require different size allens. Stripped out a few and had to replace with the next bigger size in metric due to their inconsistency. Search the forums here as I am not the only one who has had problems with their inferior products and/or customer service.
JustMe2 is offline
Old 01-16-2010 | 10:05 AM
  #33274
wingracer's Avatar
Doesn't CRC have a titanium allen screw kit? Not sure but I thought I saw them somewhere.
wingracer is offline
Old 01-16-2010 | 12:06 PM
  #33275
mike
I've been using the CRC ones for years on both my CRC and non-CRC cars and haven't had any problem with them being weak. If your finding your stripping out the allen head then you need better tools. Any aluminum or titanium screw will be prone to stripping the head out if you are using cheap allen wrenches. Look for something with precision ground tips and your screws will last a lot longer.
InspGadgt is offline
Old 01-16-2010 | 01:25 PM
  #33276
whynot's Avatar
I dont have a problem with any of the allen screws, The phillips ones that hole the lower front arm are the ones that want to strip. I have a craftsmans screwdriver,I prob. could get a newer one, or maybe just buy some stronger allen ones.
whynot is offline
Old 01-16-2010 | 01:36 PM
  #33277
Try these listed on the CRC web site; http://www.teamcrc.com/crc/modules.p...prodID=7718961
Allen head instead of the phillips screws. Are you pre-threading the lower arms before running the screws in?
JustMe2 is offline
Old 01-16-2010 | 02:07 PM
  #33278
Default wire gauge
Hi all, sorry if this question already been answered,but, what is the better wire gauge size for use in a pan car, 12awg , 14awg or 16awg, it will be used in a Assoc 12R5.1 with a Tekin RS/10.5,cheers.
Michael
TeamBear is offline
Old 01-16-2010 | 02:56 PM
  #33279
Ah...then you probably have the wrong sized screwdriver. If it is too small or the angle is too steep you will have problems stripping them. An 8/32nd tap helps too...that way you pre-thread the arms.
Old 01-16-2010 | 02:57 PM
  #33280
Michael
Most of us use 16awg in 1/12th scale.
Old 01-16-2010 | 03:00 PM
  #33281
Mugen10's Avatar
for a 10 or lower motor, 16 ga. I use 18 ga. but only run 17.5 and 13.5. No issues.
Mugen10 is offline
Old 01-16-2010 | 03:09 PM
  #33282
whynot's Avatar
Yeah that prob. is my problem,I have 2 sizes the bigger one fits better. I think I am going to get the titanium allen screws with the 3/32 allen. 20 bucks for 4 though wow. maybe just get ones from rcscrewz just for the 4 needed in the front. thanks for all the replies guys.
mike
whynot is offline
Old 01-16-2010 | 04:33 PM
  #33283
thanks InspectGadgt and Mugen10, I set it up using yeah racing 12awg wire but just seems too big for a pan car, I will get some 16awg and give that a try,cheers.
TeamBear is offline
Old 01-16-2010 | 05:03 PM
  #33284
chris moore's Avatar
I want to get a screw kit for my 12 scale gen xl, what would be a good one to get ? I want all allen screws if possible, NO phillips they seem to strip real easy, and is there any that are anodized red.
mike
I've had good luck with this place, thay dont have a specific kit for your car but if you check out the RC assortment you might find one real close.
http://www.fastener-express.com/
chris moore is offline
Old 01-16-2010 | 05:35 PM
  #33285
Josh Keller is offline
