i run at this same track as steve. i have had some of the gumming with the front tires too, but not to the same extent. have been running grey rears and purple fronts. i am getting a little push bythe end, but managable. i cut down a new set of tires sunday and i noted that after the main i had NO glazing of the front tires at all. i run more caster in the front end than you steve, i noticed this after lookig at your car. i always understood that increasing caster reduces the initial turn in. and that seems to me like where you are having the most issue. yours also had ten degrees active caster, mine is running five. just a thought for you. your car was faster when it was on it wheels for sure. my thinking was that your car is so aggressive withall the reactive and like no static caster from what i could see, that maybe adding in some caster cold be a good thing. worth a try anyway.
It sounds like you got a really dirty carpet. The dirt on the track is sucking the Paragon off the tire, then it builds up on the tire. Get a pro crew there to do a good deep cleaning of the rug. The rugdoctor rentals aren't good enough.
Originally Posted by timmay70
(Post 6722336)
Originally Posted by SteveL
(Post 6720943)
Everyone is having some issues, some worse than others. Drew Ellis runs here and his car picks up a bad push after about 2 minutes. His pushes so bad by the 7 min mark that it can't hook.:lol: I still think it has to do with all the rubber tire cars.:confused: Just looking for a good solution because the rubber guys are not going to switch to foam anytime soon, although I wish they would.
We have not tried the grey fronts as of yet but that does sound interesting. I heard a bunch of guys ran them at Cleveland this year. I think you're going to have the swapping end problem running a 1S on a t-bar car regardless of your setup especially when the grip is high. The thing is you'll probably be able to fix the swapping end issue, but also sacrificing performance of the car at the same time. I was a die-hard t-bar guy and decided to pick up a 12R5. After racing this last weekend. I'm a link car convert and amazed how easy the 12R5 was to drive and work on. If you can, I would get Keven H's setup from the recent Halloween Classic and slap it on the 12R5. You won't look back at a t-bar car... Also, is the track strictly a paragon track or all types of additives being used? If you can get everyone to commit to a one or two it might lead to more consistent track conditions. |
we only run ground effects.
What I meant is that the rug needs a shampoo. Vacuuming only will go so far. Especially Mike's, where the dirt track and carpet track are nearly back-to-back... I don't know what the situation is like out in CO, though.
(Post 6721915)
It's a t-bar car, no side springs. I ran a thin and thick. The thin traction rolled and the thick ended up hooking. Ride height in the frt is the same both sides.
Seems like the lilac and magenta fronts glazed and the blacks had build up if that makes any sense. I tried sausing the the whole frt with the black and it did not build up but the car had way too much steering and wanted to traction roll. That might work if I went up to .022 or .024 springs though. Here's my .0001 cent idea. Try the black fronts again, sauce the whole front tire but then wipe off some of the paragon off the front outside tire after a few minutes, leaving on the paragon on the inside of the tire the normal amount of time. It might work. Steve |
dont shampoo the carpet we did that one at rc madness and we ended up having to replace the carpet best way to clean the dirt off is to use a good vacume cleaner then just run on it as much as you can or soak a towel with traction compound and drag the track..
hey guys a quick questions on the jaco yellow that keep coming off the rims on the out side edge. what do you you guys recommend to glue the foam down. I would not think of usind Ca as it would create a really heard spot in the foam might soak to much up. thanks in advance
Originally Posted by cyrrus
(Post 6723132)
Originally Posted by Apex
(Post 6723181)
Also, don't round the tire too much cause it will cause chunking.
Originally Posted by kawirider
(Post 6722803)
Apex thanks for the reply. for some reason orange are really hard to find around here. I have one set of yellow left though i try and glue them, and maybe they'll last long enough till the orange one avail around here.
Originally Posted by oze
(Post 6723273)
Can you explain this? I always thought rounding the tire helps preventing from chunking.
(Post 6723353)
Rounding the edge provides more side bite causing more load on the rounded edge which in turn will chunk easier.
| All times are GMT -7. It is currently 12:50 AM. |
