-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Scottrik 08-25-2009 05:42 PM
Originally Posted by Bob-Stormer (Post 6256053)
I got no traveling buddy. :(
Yeah you do!! I'll volunteer.
Bob-Stormer 08-25-2009 06:08 PM
Grenade10 08-25-2009 08:01 PM
Originally Posted by Scottrik (Post 6253985)
That's fine on your own but leaving the inside THAT exposed when you're dicing for position is just BEGGING somebody to barge up the inside and either a) take the line away from you (best that can happen), or b) drill you in the side as you turn in. :nod:
Hey I thought we were over that Move!!!:D
HB Moose 08-25-2009 08:09 PM
Originally Posted by Danny-b23 (Post 6254643)
Anybody have any idea where I can get some retardedly small 48p spur gears?
Like smaller then the Kimbrough 69T. 72mm rollout has me running a 32T pinion. I don't even think I can fit that on a 3.2R. :lol:
Robinson Racing has them down to 60 then as Casper said there is the BMI @ 58.
rcjunkie3000 08-25-2009 08:51 PM
Cain, also check www.nexusracing.com. Here's a direct link to the CRC Gen X 12 items:
http://www.nexusracing.com/index.php?cPath=137_344
Apex 08-26-2009 06:55 AM
Don't know if anyone can answer this, but I'll give it a shot on this thread since this is the class that is using 1S LiPO's.
I have a Hyperion 0606i charger and just recently bought some of the SMC 4900 40C 1S LiPO's. I won't be using them for a month or so and wanted to run a Store charge on them with the Hyperion. When I start the Store charge it verifies there is no balancer connected, but then gets stuck in the battery check wait status and continues to beep. I was thinking maybe there is a problem with the battery. To verify this I ran a normal charge on it and it charges fine.
Anyone know what's going on here?
Cain 08-26-2009 06:58 AM
Is it waiting for you for some sort of interaction? I know on the hyperion duo the latest firmware set it to tick down and then start the charge. Maybe a firmware issue?
Apex 08-26-2009 07:08 AM
Well, it doesn't look like the 0606i has any firmware updates.
The "tick down", is it a series of beeps and then starts the charge?
Maybe I just need to let it beep for a while and see what happens.
Cain 08-26-2009 07:14 AM
Well, on the hyperion duo I have it actually is a count down saying its confirming the number of cells or voltage and if its ok to start the charge. Before my last update, it would just wait for me to press mode to start I believe. Now it just ticks down then starts. Its a 9 second tick down.
What are opinions on the following 17.5T motors, namely fit in CRC Gen X with brushless rear pod and performance:
- LRP X-11
- Tekin Redline
- Novak Ballistic
- Hacker
This would be used with a Speed Passion GT 2.0 ESC.
Scottrik 08-26-2009 03:18 PM
Keep in mind that, unlike the NiMH batteries of the last several years, as far as a LiPo is concerned "a month or so" isn't "storage"...it's just a little break between races.
andrewdoherty 08-26-2009 03:31 PM
My hyperion 0606i won't put a storage charge in the 1 cell lipos wither. I have 8 packs, 4 brand new and 4 older, and they all do the same thing. I think the software requires you have the balancer plugged into the battery to use the storage feature.
Customworksking 08-26-2009 04:06 PM
1/12
I been out of the 1/12 loop 4sum time what jaco tires will b good to run at iic this year ? running 13.5 xray car
andrewdoherty 08-26-2009 04:12 PM
I'm pretty sure the consensus will be Oranges in the rear and dbl pink, black, or lilac in front.
chris moore 08-26-2009 04:56 PM
Anyone know where to get these orange's? I checked Stormers and Ashford but neither even lists an orange compound under the Jacos.
Kave 08-26-2009 05:19 PM
Thats an issue. But orange is the way to go!
