1 Attachment(s)
Originally Posted by andrewdoherty
(Post 5867378)
Initial testing is going very well. Chassis, that is. Looking forward to testing the TP bat. Brian |
Where can I get one of these batteries?
Clay |
Originally Posted by clayrace24
(Post 5867792)
Clay |
I was thinking about getting into this class, but it don't seem to have a following in my area.
Ok super noobie question. How does one "glue" the sides of the tires to help prevent them from chunking? I have heard of this but not sure what kind of glue or if there the is a special technique to doing this.
thanks guys! |
Ok one more. I hear of guys who "clean" there foams. Any special tricks to this as well. Do you always clean them after a run before you sauce again?
125R question
What keeps the tweak springs from popping out with the linl setup. The ball on the bottom doesn't seem to kep the spring centered weell and I'm thinking the first time I hit a rail that the springs will pop out. Am I missing something?
Also, I always thought that tweak was checked by lifting the rear tires, but instructions say to lift the front. Why is that? Clay |
Originally Posted by Casper
(Post 5882307)
Hi Mangoman, you can either get them from Action Model Centre here in the Uk, or directly from Fibre-lyte themselves, who make them. Cheers!
Oh, I forgot to ask, I am living here in the USA for a couple of years and have a question about the tyre additives used here. I bought a bottle of Paragon FX, but the some of the guys at the track are using Paragon Ground Effects. Could someone let me know the differance between them? The Ground Effects stuff seems a bit more smelly over the FX stuff but will both work equally well or should one be used over the other in certain situations? Many thanks, Chris.
Originally Posted by wingman2
(Post 5883284)
Weren't you supposed to move to the VA Beach area? If so, where are you running? |
(Post 5882260)
(Post 5882307)
Hello 1/12th guys :), here are some drivers running with a 1/18 packs (1800-1900 mAh Lipos 7.4v) is his 1/12 cars, with 10.5T BL motors, i´m a bit old, and i only know, this car running with 6 cells, and lately with 4 cells, i read about 1S Lipo 3.7v, in this car,too.
But im interesting in the 1/18 packs,and how they behave in these cars, if someone has some experience in this, i would like to know something more. Now i have a futuristic car, :sweat:, Gen-X, and i would like go back to this beautifull category. Greetings, Luis C. |
Originally Posted by LAGuy
(Post 5884006)
Nothing special. Use thin CA glue on the sidewalls only. A little goes a long way. I mainly use this to stiffen up the sidewalls to prevent traction rolling on real high bite tracks.
For foams on carpet, I use CRC Non-Chlorinated Brake Cleaner (The Green Can). It works great and is only a few dollars a can. No ill effects that I've ever noticed. I saw someone once soak their really small foams in cleaner (Stick-ET) and the glue actually dissolved a bit and the foam spun off the wheel at the start of a race! But we never "soak" the foam. You spray the cleaner onto a paper shop towel and then wipe down the foams. CRC brake cleaner from an Automotive store. I am assuming you don't mean Calandra Racing Concepts or do you? |
| All times are GMT -7. It is currently 01:22 AM. |
