-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
RCSteve93 12-22-2008 06:12 PM
Originally Posted by jorgesimes (Post 5197843)
sorry for this quick question, what is the best 1/12 based online store?
Teamcrc.com
PartTime 12-22-2008 06:57 PM
Originally Posted by Crashby (Post 5198547)
The first thing I did to try and fix the problem was put 1/8th balls in the diff. While that helped a little, it still binds up and when you take the diff apart, you can see galling on the back side of the orange aluminum cup where the thrust bearing race is rubbing. I think the aluminum cup is not deep enough and it is bottoming out on the end of the graphite part of the axle. I did try and remove a little of that part of the axle and, again, while it did make it a little better, it still binds. I thought maybe when the hole was drilled in the end of the axle for the set screw, that it expanded the graphite and is causing the cup to bind. I sanded down a little of the graphite and that also made it a little better but it's not perfect. I think it's a combination of a lot of tight tolerance issues. I will keep working on it.
Don't get me wrong. I love this car!! As with any fine piece of racing hardware, it takes a little massaging to make it perfect.
I know this sounds simple and I dont want to insult you but, did you try the diff with out the tire ??
DK
odpurple 12-22-2008 07:18 PM
DK
Go ahead and insult him. Its fun, I do it all the time :nod:
theisgroup 12-22-2008 07:20 PM
crashby seams to be the norcal whipping boy. lol
Crashby 12-22-2008 08:04 PM
Originally Posted by Slapmaster6000 (Post 5197796)
I haven't had a Serpent S120 in my hands yet. The proto pic's I saw appeared to have copy of my design.... so I expect you wont need one. But incase that it doesn't come with a thrust bearing, then I could recommend one if I get the spec's from the axle. Just in case it's metric, let me know that axle diameter, the threaded stud diameter and the length the axle sticks past the hub bearing. This pic shows the axle is .130" past the hub bearing as an example.
Brian
Ok, Mr. Bodine!!
Here are the measurements you asked for on the Serpent S120.
Axle diameter = .25"
Threaded stud diameter = .157"
Length the axle sticks out past the hub bearing = .030"
What do you have that will fit?
B.L.S. 12-22-2008 08:25 PM
What parts are needed to convert the two bolt axle on the associated 12LC to the current three bolt? Thanks
Slapmaster6000 12-22-2008 11:21 PM
Originally Posted by Crashby (Post 5199679)
Ok, Mr. Bodine!!
.030" is pretty short. The shortest delrin spacer I have in stock is the #101 kit for 12th scale at .140" over all length. The issue that you "could" run into is the nut may not get completely on the threaded stud. The included aluminum nut is a 8-32 about 3/16" thick or .1875". Add the .140 spacer and your threaded stud can not be any shorter then .3275" from the end of the hub bearing to work correctly. .157" sure sounds like the diameter for an 8-32 stud.
Truth be told, all the S120 drivers need is a delrin spacer upgrade, not an entire thrust kit.
Funny thing is... I did some prototype parts for Serpent back in '03-'04. Can't say that it ever worked out for me. Guess that's why I am doing my own thing now.
Slapmaster6000 12-22-2008 11:24 PM
You can check out IRS's website for 3 bolt hubs and clamp hubs. Check to see if you need stealth rings or large ring. I thought the L2 was stealth.... but it's been a while!
InspGadgt 12-23-2008 03:29 AM
The 12LC used the small Stealth Diff diff rings so you'll need a 3 bolt hub that works with those and a clamping 3 bolt non-diff side hub. IRS and CRC both make complete axle assemblies that would be much easier and better then using the LC axle with new hubs. The LC axle had a flange part of the axle that the diff gear spun on, the newer axles use a bearing there and makes for a much smoother diff.
AdrianM 12-23-2008 05:43 AM
All the new BMI Big Wheel pinions 45T-60T are online and for sale now.
www.bmiracing.com
jdeadman 12-23-2008 05:59 AM
I'm using a Novak GTX and Checkpoint Money 19T Motor. But I need to get the Silver springs and brushes to get a bit more tourque out of her
and I use CheapBatteryPacks.com 4000 mAh Batteries And I can get within .5 of a sec lap times from the big boys
jiml 12-23-2008 06:38 AM
Yea but it's getting that last half a second that will drive ya broke!:lol:
jdeadman 12-23-2008 07:57 AM
not really.. I am just starting out and I bought one of the "top" guys old card and I have done alot of research mostly on this site (way to go guys) anyways and I have just started slow. learned how to drive (coming from MT racing this is totally different) But I am getting better and as long as I can still improve even if it is only my Standard Deviation.
Getting the hang on the car and how it reacts to small changes is the key!!! to racing 1/12 scale. as afar as I'm concerned if your car is not setup correctly it really does not matter how well you drive you will not be able to improve.
But this being said the hardest thing in Racing is the mental preparation and calmness needed to get these speeding bullets around the track . I have seen it too many times when a top driver has a crash even a minor one then tires to catch up but continues to make mistakes after mistakes eventually loosing time and money due to broken parts.
I have tried to stay positive and keep in mind this this is a hobby and is supposed to be fun.
Wow that was a long ramble.
Cheery guys and thanks for all the help and advice
tellan 12-23-2008 09:11 AM
Tekin redline 10.5bl
Just purchased a redline 10.5bl
I run a Corally sp12x 4 cell with a an RS esc.Suggestions needed for roll out would be appreciated.
theisgroup 12-23-2008 09:14 AM
I ran a sp 10.5 in a rev 5 and was around a 61mm rollout.
