Originally Posted by Racermac73
(Post 14698129)
if the carpet is from the batch that fuzzes up then go to the double blue front.. lilac/team purple gets sticky and the fuzz will stick to the tire. if its really bad try green rear with blue or double blue front
Originally Posted by X marksthespot
(Post 14698108)
Thanks for the help,right now i will try anything to get this car running better.Yes the carpet is old and it has seen better days.So many different tires and combos to try its a little confusing for a rookie.Cant find the team purple/lilac combo is double purple the same as purple/lilac?
Originally Posted by chris moore
(Post 14698182)
It's team purple or lilac, not a combo. BSR is the only brand that makes the team purple as fas as I know, lilac is available from a few tire brands. And no double purple is not the same.
Same foam, mounted by the same company but called different things based on brand. Little confusing .. but they are the same. |
Thanks a bunch guys,helps a lot
Originally Posted by ByteStream
(Post 14698431)
BSR Team Purple = Jaco Lilac = CRC 'WGT Stripe"
when you use the hudy tweak station
do you put the front wheels on the fix side and the rear wheels on de bubel side ? thanks |
Originally Posted by truggy100
(Post 14699243)
(Post 14699243)
do you put the front wheels on the fix side and the rear wheels on de bubel side ? thanks Also, disconnect the side tubes when doing it. |
(Post 14699243)
do you put the front wheels on the fix side and the rear wheels on de bubel side ? thanks If you set the car up right you really don't need a tweak station. |
Black Carpet Tire Selection
Hey again guys and girls,
At the moment I am running CRC spec tires on the black carpet, they aren't bad. But, does anyone know of a faster combination than spec? Our WCICS rules state open foam for both Mod and Stock 12th scale, so I'd like to give different tires a try. Thanks, Colin |
Originally Posted by ColinH
(Post 14699447)
At the moment I am running CRC spec tires on the black carpet, they aren't bad. But, does anyone know of a faster combination than spec? Our WCICS rules state open foam for both Mod and Stock 12th scale, so I'd like to give different tires a try. Thanks, Colin http://www.wcics.ca/pdfs/2016-2017-WCICS-Rules.pdf The website is in need of maintenance as the rules are not available from a link there. |
Originally Posted by KingJohn
(Post 14699486)
Don't look too hard... the current years rules show spec tire.
http://www.wcics.ca/pdfs/2016-2017-WCICS-Rules.pdf The website is in need of maintenance as the rules are not available from a link there. Either way, probably going to be running mod 12th too... we'll see how that turns out. |
5mm I believe
So does everyone here have there own tire lathe? Got the car finally and it sounds like its kind of a must have.
| All times are GMT -7. It is currently 04:27 PM. |
