-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Slapmaster6000 12-22-2008 10:00 AM
Originally Posted by Randy Caster (Post 5197206)
Direct order is the only way I know to get them. I sent PayPal and had the thrust at my door 4 days later with the free shipping. www.slapmastertools.com
Would have been 2 days if the postman had picked up. We are kind of digging out of the snow banks around here. Watching the news is entertaining. Everything is crashing around here. The scary one was the school kids in a bus hanging over the edge of I-5 after it broke through the guard rail! Darwin would have a field day here.
Randy Caster 12-22-2008 11:28 AM
Haha, 4 days was fine by me, I'm in no rush, but I'll expect 2 days when I need another ;)
Crashby 12-22-2008 11:44 AM
Originally Posted by Slapmaster6000 (Post 5197293)
Oh Great.... now everyone is going to want one!
Actually, thanks for the props! The website just had a few updates. I have to bust out the iron and smooth out a couple things still. With the increasing variances in axles, I have had to come up with a few more thrust kits. Here's some quick references:
#101 will fit: these 12th scale cars; Associated, IRS, CRC, CEFX, BMI, Speedmerchant, and these WGT Cars; Asc 10R5, Speedmerchant Formula 10.
#109 will fit: 12th scale Niftech axles, Asc 12R5 with the 10R5 b/l converison.
#110 will fit: most known 10th scale oval chassis.
#120 will fit: CRC GenX10 WGT.
Brian
Hey, Brian!!
Which one fits the new Serpent S120?
Slapmaster6000 12-22-2008 12:30 PM
1 Attachment(s)
Originally Posted by Crashby (Post 5197646)
Hey, Brian!!
I haven't had a Serpent S120 in my hands yet. The proto pic's I saw appeared to have copy of my design.... so I expect you wont need one. But incase that it doesn't come with a thrust bearing, then I could recommend one if I get the spec's from the axle. Just in case it's metric, let me know that axle diameter, the threaded stud diameter and the length the axle sticks past the hub bearing. This pic shows the axle is .130" past the hub bearing as an example.
Brian
jdeadman 12-22-2008 12:33 PM
Originally Posted by Slapmaster6000 (Post 5196999)
There are two really good ways to mount up servos for ackerman reasons; flat and in the mounts. The CRC front end likes to be in the mounts (angled) according to testing. Many have called the Prostrut front end a pure carpet front end... which is hard to believe after the great results at asphalt worlds. Flat or glued seams to pair up very well with the Asc Dynamic front end. When going flat, try to use the middle hole on the servo saver. If you use the upper set, you increase bump steer flattening out the links. When you use a flat servo, you want to use the tallest ball studs on the spindles you can without interfering with the wheel with it turned. Ackerman on the servo saver can be thought of as various angles of a V. The center bottom of the V is the servo saver screw. Tighten up the V, you will reduce ackerman. Open the V up, you increase ackerman. When you mount the servo flat on the chassis, fore and aft location also creates ackerman which has more of a profound effect. If you were to stretch a rubber band front spindle ball stud to spindle ball stud and your servo saver ball studs just happen to line up with the rubber band, you would have the least amount of ackerman. Drag the center of that rubber band forward, you increase ackerman with link sweep. What does this mean? The least amount of ackerman makes the car more forgiving "from center input" at the tx wheel then more ackerman. If you need to more steering input after several other major adjustments have been made, consider your ackerman. Tracks that are lower in grip can use more ackerman then tracks that are gummy or like fly paper. The CRC front end has a lot of forward sweep, but then again, the steering spindles are a different shape.... so it all needs to be considered as a complete package.
Ackerman is a very powerful adjustment after the conventional adjustments have been made.
Brian
Brian I can;t thank you enough Great Post
Crashby 12-22-2008 12:37 PM
Brian
The S120 kit does come with a thrust washer system much like yours but it does not work. It goes into terminal bind when you tighten down the nut. I can't tell if the aluminum cap that contacts the outer bearing race is rubbing on the OD of the axle or if it is bottoming out on the end of the axle. I tried sanding down the diameter of the axle a little and put in 1/8th diff balls and it was slighty better but still not serviceable. It would still bind. Right now I am just using a CRC collar and doing the diff the old fashion way but I would like to use a thrust washer system if I can.
I will get the measurements and send them to you.
jorgesimes 12-22-2008 12:44 PM
sorry for this quick question, what is the best 1/12 based online store?
Slapmaster6000 12-22-2008 12:45 PM
I wont lie, I have ran into that one of my kits. The difference between the 12th & 10th scale thrust kit is only .010" just to clear the end of the axle.
You say the Serpent car has an aluminum spacer from the hub bearing to the thrust washer? Is there a belleville washer or some other form of "crush" for setting tension? Maybe even a nylon nut?
If you are using a CRC collar, there's a good change my 12th #101 kit should work, but lets look at the dimensions first.
bb
Crashby 12-22-2008 12:51 PM
You say the Serpent car has an aluminum spacer from the hub bearing to the thrust washer? Is the a belleville washer or some other form of "crush" for setting tension? Maybe even a nylon nut?
bb
Yes. The kit comes with three bevel washers after the last thrust bearing race and before the nut.
theisgroup 12-22-2008 12:57 PM
hey crashby, this is not your personal support forum. lol
say hey to tim
dj apolaro 12-22-2008 01:05 PM
Hey guys,
I have a question. I am going to start running 1/12 scale carpet and have a few questions. There is a chance I might use Orion products, but not sure. For the 19turn class what is the best motor/speed controler and battery combo(orion or other brands). Also what is the best JR servo to use. Also If you have any ideas that will help me that would great. I am fairly new to 1/12scale but not new to the hooby. I am looking for the best stuff for high level competition racing. I will be running the serpent S120 at some of the major electric events this year.
Thank you for the help,
DJ Apolaro
Julius 12-22-2008 01:57 PM
Did you use the kit supplied balls for the diff?
If so I'm 99% sure your problem is not with the thrust bearing.
Use 1/8th balls and the diff should work perfectly. We've had some issues withthe thread running out prior to setting the correct tension. But I've not seen or hear anything being wrong with the thrust bearing setup.
CraigM 12-22-2008 02:01 PM
+1 :confused:
thanks
Crashby 12-22-2008 04:08 PM
The first thing I did to try and fix the problem was put 1/8th balls in the diff. While that helped a little, it still binds up and when you take the diff apart, you can see galling on the back side of the orange aluminum cup where the thrust bearing race is rubbing. I think the aluminum cup is not deep enough and it is bottoming out on the end of the graphite part of the axle. I did try and remove a little of that part of the axle and, again, while it did make it a little better, it still binds. I thought maybe when the hole was drilled in the end of the axle for the set screw, that it expanded the graphite and is causing the cup to bind. I sanded down a little of the graphite and that also made it a little better but it's not perfect. I think it's a combination of a lot of tight tolerance issues. I will keep working on it.
Don't get me wrong. I love this car!! As with any fine piece of racing hardware, it takes a little massaging to make it perfect.
hairy 12-22-2008 04:17 PM
