-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
ovalnator 08-24-2001 02:46 PM
Taz_S 08-26-2001 02:44 PM
to bad it was a good race but it was hot.
psycho 08-28-2001 01:25 PM
Hey guys. I have a question for you. I plan to start racing 1/12 and my lhs races them as either 6 cell/stock motor or 4 cell/modified with a receiver pack. There is an unwritten rule that thou shalt run a 14T, if modified. Anyways, they run both configurations together, as there aren't that many cars. I'm trying to decide which way I should go. I plan to race with a CRC Six Pack, so it will work with either configuration. On the surface, it seems like the 4 cell/modified would be the way to go due to the weight reduction, but then again, 6 cells has more voltage.
Any input would be appreciated!
Taz_S 08-28-2001 01:28 PM
shoot a 14t would not last around here for long. WE run 10, 11, 12 with 3000's in 4 Cell mod.
I like 4 Cell better lot less wear on the com and tires. Then 6 cell stock.
Geppetto 08-29-2001 04:51 AM
JeffC: I had a Carpet Knife (v3.0 converted to v.3.1) for about 1.5 years. I found the car to be very easy to drive (once I made the transition from Touring car to 1/12). I used Losi medium Hydra Fluid in the damper tubes. I raced at "The Track" in Maryland. This is a rather large indoor carpet track. Several of the other drivers there are CRC sponsored drivers and that's what they recommended.
I sold that car about 3 months ago, but I'm considering getting a Corally (just to be different) for this season.
Taz_S 08-29-2001 09:52 AM
Harsh guy---- I personally think if you are going to run mod then 4-cell is the way to go.. I would also say if you re running 6-cell stock and have a choice to run 4-cell mod to try it . In the long run you are going too save the equipment better..
At the nat's here is my setup for SWR raceway.
Motor Reedy TI 9 Turn double. Geared 23/104
Reedy panasonic NIMH
Associated car . 20 front springs.. 3 degrees caster.. 60 wt shock oil. With the GReen spring.(softest) .063 t-bar without the center screw...
I ran #4 ride height carries and no spacers under the front end.. I ran 10 degree blocks on the front end..
I used dampner tubes instead of the dampner discs. I put Trinity red stuff in them and ran brp silicone on my front kingpins.
Tires.. I ran purple fronts size 1.73 I ran pink rears size 1.90 I also used paragon for 15 mins on the tires wiped them off then applied coppertone 45 sun tan lotion until the heat before i was up then wiped dry and much as possible...
Hope this helps you guys
Mike Blackstock
I got it off of RcRacing.com
http://www.rcracing.com/msgthread.cf...turn=20#134286
TFR 08-30-2001 04:34 PM
please dont mind me asking a stupid question...
but is all the AE 1/12 for oval racing??
i m looking for a road course like 1/12...
which brand or model do you guys run??
TFR 08-30-2001 04:36 PM
i m very interested at the 1/12 cars now...
i got a F103 and i personally thinks its fast already...
but i heard all the ppl say that 1/12 will blow by a F103 ....
and so far, my skills is just keeping up with some stock guys...
:D
Taz_S 08-30-2001 04:38 PM
OK there a 12L3 and a 12L3O
The one you want to get out of the two is the 12L3 that the road course car.
daniz24 08-30-2001 04:41 PM
Are you running 6 cells or 4 cells?
psycho 08-30-2001 04:42 PM
TFR
You might also check out the Calandra cars. They're based on Associated parts, but less expensive. http://www.teamcrc.com/CRC%20Main.htm
Taz_S 08-30-2001 04:47 PM
you got your car yet psycho?
psycho 08-30-2001 04:50 PM
Taz_S
I have a 3 bolt 6-Pack. Very cool car.
Taz_S 08-30-2001 05:07 PM
Cool when the next race you going to with the car.
psycho 08-30-2001 05:41 PM
I race with a bunch of buddies and we're racing this Sunday. I plan to race 1/12 and F1 at Castle on 9/16. Some of the guys I race with will be at Castle too, so hopefully we'll add another 4 or 5 cars to the 1/12 race.
