Originally Posted by odpurple
(Post 3425480)
Smojoe=comic relief :lol:
After we switched to Paragon the bite issues went away and the usual compounds worked. Grey/Purple or Pink/Magenta were fine. And really, the only problem with the triangular tires is finding a good triangular tire truer :nod: |
Originally Posted by AdrianM
(Post 3425276)
In a week or two Schumacher USA will have RW 64p spur gears in 78, 82 and 85 teeth in addition to the 88, 92, 96 and 100 teeth 1/12th gears they already stock.
These gears were created specifically to allow 1/12th racers to get the ratios they need for 13.5 and 10.5 BL racing. This news makes me very happy... Please post up here when they are ready for purchase. I already love the RW gears on my TC, and never thought about checking to see if they made 12th type. -Shookie <>< And yes the kimbrough diff covers work for both 48 and 64 pitch gears. |
(Post 3425480)
And remember...right triangles are just plain wrong. The grip like a bunch of pissed-off road monkeys...for about 2 minutes. |
Originally Posted by Scottrik
(Post 3426001)
I've found that my bench grinder does a pretty good job. From there it depends on what sort of triangle you find runs fastest for you. While many find an equilateral triange to be the fastest on a more open track some have decided that an Isosceles triangle offers better on-power steering on tighter layouts. I've been experimenting with a scalene triangle set-up that seems promising.
(Post 3426152)
Math Geek! :lol:
novak gtx
Hi,
can anyone help me with my novak GTX ? I'm trying to rewire it but can't solder the wires loose (even on 420C... 710F, don't think I should go warmer uhm...!?). What do I wrong? thanks, v12 |
Originally Posted by V12power
(Post 3426261)
Hi,
can anyone help me with my novak GTX ? I'm trying to rewire it but can't solder the wires loose (even on 420C... 710F, don't think I should go warmer uhm...!?). What do I wrong? thanks, v12 I just rewired my GTS wich is very simmilar, Novaks are not easy to rewire, but here is what I did. After you remove the old wire, there is probably some left over solder in the holes, heat up that solder and remove it (either with a solder sucker, desoldering braid, or if you don't have those lightly tap the ESC against the table) once you get the solder out of the holes strip and tin your new wire (be sure you twist the wire as tight as you can before tining) to make soldering the new wire easier use a piece of servo tape to hold the ESC to the table next place the first wire over its hole then apply heat to the bottom and push the wire through, repeat for the remaining wires |
(Post 3426261)
Hi,
can anyone help me with my novak GTX ? I'm trying to rewire it but can't solder the wires loose (even on 420C... 710F, don't think I should go warmer uhm...!?). What do I wrong? thanks, v12 Also, use some flux on the wires and put a little blob of solder on the iron to aid heat transfer. |
(Post 3426231)
For that crack you don't get the magic angles on my scalene. :sneaky:
does the 12b body fit a 12l4 guys?
and it doesnt look like it, but does the rear of the body have fender wells? i hope not.....doesnt look like it, but somethings in person are different lol |
(Post 3426507)
Now you're just being obtuse :D
Originally Posted by BlackedOutREVO
(Post 3426518)
and it doesnt look like it, but does the rear of the body have fender wells? i hope not.....doesnt look like it, but somethings in person are different lol http://i158.photobucket.com/albums/t...ndo/1610-3.jpghttp://i158.photobucket.com/albums/t...kendo/1610.jpg |
Originally Posted by Big B
(Post 3426579)
Yes it fits, all of the Protoform speed 12 bodies are made specificaly for 12th scale pan cars. If you go to the http://www.protoformracebodies.com/ or http://www.parmapse.com/websites they have all the info on all their bodies. What do you mean by fender wells, like an inner fender? A 1/12th scale body is just like a 1/10th in that it is just a shell, no inner parts.
http://i158.photobucket.com/albums/t...ndo/1610-3.jpghttp://i158.photobucket.com/albums/t...kendo/1610.jpg and sweet, just making shure, in the description it says fits most 12th scale cars |
Does anyone have a set of servo mounts they want to get rid of?
novak gtx
od purple - Big B , thanks for your help/input !
(temp., watts are too low, am using the smallest tip you can imagine.... so i was doing everything wrong :( - will buy better iron :D) cu, v12 |
| All times are GMT -7. It is currently 04:00 AM. |
