-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
David Galdo 02-18-2007 06:01 PM
P2, looks like ya had some fun down there..... when are you making a road trip for a warm-up to the Taxas State Championships?
SARCAR_Revmax 02-18-2007 06:05 PM
I'm bringing out the Grandpa of all 12th scales again, and was wondering what a good upgrade would be from a 12LS? *acts embarrassed because of the age of the car* :lol: :lol: :lol:
protc3 02-18-2007 06:06 PM
Originally Posted by EAMotorsports
Every car I have ever driven with a Tbar (oval and on-road) has had at least .010 under the front Tbar pivot. It seems to give the car more steering on power which helps pretty much everywhere. I know my CEFX car at the birds had .050 under the front pivot. And I know of a LOT of other drivers going back to Tbar cars on carpet now after the past two major 12th scale races.
We shall see at the Nats next month!
EA
cool.i have always been a big fan of the T bar cars.thats what i was after with my new car.i am working on new center springs now which i think are going to finally give me a complete T bar feel and also let me have more adjustment than the T bar.keep your eyes and mind open dude.i think this is going to be real good.the car is better than expected already.this is going to put the icing on the cake. :sneaky: :sneaky: :sneaky:
adam lancia 02-18-2007 06:27 PM
Originally Posted by adam lancia
cool arms!
question about tires (i know, this is always a loaded question). what are the differences between jaco and crc foams? specifically the high rollers vs the regular jaco's? am i right to assume that since the high rollers have less foam on the rim, that effectively stiffens the feel of the foam since there is less foam to spuish...? and would the opposite be true for the crc's? the reason i ask is because i was running some white jaco's and chunked them so i changed them out for what a fast guy recommended which was high roller whites. it pushed much more with the whites so i went to high roller pinks and it was still pushing. it was more balanced with the jaco whites on the rear. if anyone could give me some guidance, it would be a great help. thanks!!!
can anyone answer this for me or is it too broad a question? ANY feedback would be awesome, thanks guys.
EAMotorsports 02-18-2007 06:35 PM
Your car is going to be dialed after a little more time with it...Hell it was pretty damn good at the birds!!
I know in my experience with pivot ball Oval cars the center shock and center shock length were two of the most important adjustments to how the car steered.....So if you can figure springs out for it and get them dialed in your car will be unbelievably good!!
EA
protc3 02-18-2007 06:36 PM
in a nutshell,a bigger tire has more contact patch and more forward traction.the purpose of high roller tires and wrap tires is to allow for less of a sidewall while still achieving a larger contact patch for added forward traction.if you run high roller rears you need fronts also to balance the car out.the diameter spread will be too much.if you run white high roller rears with say purple or black fronts and your car pushes,chances are,your setup needs help.post your setup,type of car and tires and im sure we can point you in the right direction.
protc3 02-18-2007 06:45 PM
EA
we did mess with shock length at the birds.that comment is sooo true.i have 2 positions for the antenna mount to allow for length adjustment and we tested with both.Pdubs car had it set longer and mine was in the short position.unfortunately we were all lab rats for the first time out. :lol: the only problem i ran into at the birds was time.so much to get dialed in in such a short amount of time.we did get it pretty good but i think it has alot more in it.the biggest problem i am finding with isolated rear suspension is that with the T bar cars,your front to rear spring tension is extremely progressive being that the spring tension is from the spring and also from the forward flex of the Tbar.with the link style cars,you lose that all together and now you are stuck with an extremely linear spring.i have the progressive spring tension with the twist of the rear pod,now i want it for compression.with the new springs i will have that but with it being extremely controlable and adjustable for different surfaces. :)
Marcos.J 02-18-2007 06:54 PM
we did mess with shock length at the birds.that comment is sooo true.i have 2 positions for the antenna mount to allow for length adjustment and we tested with both.Pdubs car had it set longer and mine was in the short postion.unfortunately we were all lab rats for the first time out. :lol: the only problem i ran into at the birds was time.so much to get dialed in in such a short amount of time.we did get it pretty good but i think it has alot more in it.the biggest problem i am finding with isolated rear suspension is that with the T bar cars,your front to rear spring tension is extremely progressive being that the spring tension is from the spring and also from the forward flex of the Tbar.with the link style cars,you lose that all together and now you are stuck with an extremely linear spring.i have the progressive spring tension with the twist of the rear pod,now i want it for compression.with the new springs i will have that but with it being extremely controlable and adjustable for different surfaces. :)
http://smileys.smileycentral.com/cat/4/4_17_209.gif
protc3 02-18-2007 06:56 PM
:lol:
CarlosG. 02-18-2007 07:01 PM
He already had his warm-up in Nebraska this week. He took his car with him to race after he was done with his job he had to do up there. I am thinking of coming up on the first weekend in March, like the 3rd . I am going to see if I can get some more people to come with me.
Kraig 02-18-2007 07:02 PM
Hey EA, which front width chassis are you running for your CEFX car?
P2 02-18-2007 07:06 PM
David, Not sure if I can make it up there before the race. As CarlosG stated, I was in Omaha last week and got a chance to run my carpet car for the first time. At least I plan on going this year!
EAMotorsports 02-18-2007 07:07 PM
Its the standard Evo2 chassis as far as I know. I dont have any shims on the front axles. Outside to outside is a little less than 6.5 inches.
EA
Kraig 02-18-2007 07:11 PM
EA, do you have the Associated front end on the car?
protc3 02-18-2007 07:13 PM
hey eric,you gonna do any asphalt 1/12th?gotta love the speed of mod 1/12th on asphalt :nod:
