Originally Posted by brianrice
For Mod, you'll want to use either Parma Violet fronts, or Magenta... and the rears will most likely be Pinks. :tire:
What he said-cause Rice is way faster than me!! bastard!! |
Originally Posted by odpurple
Here's my old favorite
Originally Posted by Apex
Is that a Bud's P35 body?
Protoform Nissan P35 GTP
I have several of the P35 bodies in stock.if interested e-mail [email protected]
Nylon Locknut replacement?
Hi,
as total newbie to 1:12 , please would you give me some advice: I have here an ASSOCIATED RC12L4. just finished and have rebuild the diff, as I thought it was not smoothenough. tried to lock it up with the standard nylon lochnut ( part nr 4185) and this nut went nuts... I cannot put tension on it, it slips over... Sure there must be an alternative locknut from alu ? anybody? |
Originally Posted by octavio
Hi,
as total newbie to 1:12 , please would you give me some advice: I have here an ASSOCIATED RC12L4. just finished and have rebuild the diff, as I thought it was not smoothenough. tried to lock it up with the standard nylon lochnut ( part nr 4185) and this nut went nuts... I cannot put tension on it, it slips over... Sure there must be an alternative locknut from alu ? anybody? http://www.fastener-express.com/inde...S&Category=218 |
finally finished my Hammer12..
it's been 4 yrs since I raced 12 scale with all the new motors available.. what would be my target rollout? stock 27T.. CO27 or Epic X? checkpoint 19T Mod? lmk thanks |
If you can get a 19t class going where you race, I think you will be really happy. 19t is just fast enough, and not too fast... it is also easy to make runtime..
it's been 4 yrs since I raced 12 scale with all the new motors available.. what would be my target rollout? stock 27T.. CO27 or Epic X? checkpoint 19T Mod? lmk thanks Assume 90' stright, Ozite, fast infied: Stock MOnster 1.78" CO27 1.90" Epic X-dont know yet....but I'd start at 1.85" Checkpoint ?? 19t Chameleon 1.85" Mod cannot remember-doh!! |
Kingpins?
On the SP12M AE, the Front Susp. kingpins I am having problems with. They both are new and so are the bearings. When I go to put the knuckles on they stick, or jam? Am I supposed to polish them or something or can I?
Thanks. |
i reamed the steering knuckle with a 1/8th reamer where the kingpin goes through.they are always really tight
I use an 1/8 reamer. If that doesn't open it up enough then I roll a piece of 6oo grit sand paper and sand until the pin slides smoothly.
before you do any of that make sure to install the axles. some times they put pressure on the hole and can compress it a little bit. E |
that too.i forgot about that.those damn axles are real tight also. :lol:
If you're talking about the std 12M front end (i think so), i had some king pins that were a touch oversize right at the top. Fine down the bottom near teh wishbone, just tight at the top. I just "polished" them right at the top with some 600grit sand paper.
Heads Up.......
Just a heads up if anyone is looking for a Futaba S9602 servo for there 12th.
http://www.rctech.net/forum/showthread.php?t=126187 |
| All times are GMT -7. It is currently 02:22 AM. |
