Originally Posted by SlowerOne
Same here. Trinity wheel washers mean never having a wheel out of true, or one snap off from the centre. Best tuning aid out there for keeping tyres concentric to the axle! :cool:
You would be surprised how I need to be reminded that I have PM. I need a big stick to hit me in the head to grab my attention. Maybe the moderators could have us sellect some kind of blinking option to allert us.
Mark, I don't have a real answer for you, but you could check out their website. I would imagine that the lower outside hole is the same as Asc. bb |
Originally Posted by E-BUSS
Hey Folks
Can anyone tell me which Hitec servo(s) are suitable for use in the AE RC12L4 and where to start at for tire selection on carpet. Thanks A drunk gerbil would be able to find center more often than a Hitec servo. Hitec servos are garbage... |
Originally Posted by dr_hfuhuhurr
NOOOOO, I'm sure others have said this but I HAVE to BEG you not to get a Hitec servo. The only time a Hitec should be used is when you really don't care about centering the servo.
A drunk gerbil would be able to find center more often than a Hitec servo. Hitec servos are garbage... The hitech servo in my 12th has worked fine... but then it again it's sorta like cheap, knock-off brand guitars (like epiphone)-mostly junk but maybe one in a hundred or so is actually real good., maybe if you get one made on a tuesday as oppossed to on a friday when someone is drunk :lol: . |
i need help
question guys
i just bought a 12L4 and i wanted to replace the front axle. i don't like using the e-clip to take out the front tires. any suggestion on what to use on that, i want something you can put a nut. |
Originally Posted by tony q
question guys
i just bought a 12L4 and i wanted to replace the front axle. i don't like using the e-clip to take out the front tires. any suggestion on what to use on that, i want something you can put a nut. PSE, good axles no clips. |
question guys
Originally Posted by Seano
I'd recommend the CRC titanium threaded axles. Heres the link http://www.teamcrc.com/crc/modules.p...od&prodID=4115 :)
Bettery yet, Lunsford offers a complete Ti kit for the front end. $36.70 gets you their Ti axles, Punnisher Ti tie rods, Ti 6-32 camber turnbuckles and Ti kingpins. See it at Lunsford 1/12 front end kit PLUS they're super-nice people to deal with. I figure CRC gets enough of my dough ('nuther $80 today...) so I like to spread it around a bit. Scottrik |
and if you order directly from Lunsford, grab a 4 pack of the 8-32 flat head screws for the front end. Get rid of those annoying phillips head screws.
Scottrik Still laughing my a$$ off about the drunk gerbil |
12L4 MOTOR INSTALL
I just bought a new 12L4 and I was going to install the motor and I can not get it to fit correct. I can get in the pod area but when I tighten or try to tighten it down I can not get it to set correct. I am using a CO2 motor and I have no idea what I am doing wrong. It looks to me that the holes in the plate do not line up with the motor and the motor is hitting the T-Plate. I am using a 64 pitch 35 tooth with the stock spur gear. Is the motor can to big? I have been out of the hobby for over 3 years and I never had this problem with my last 12th scale. Did something change in the past 3 years? Can anyone give me ideas on what to do. Thanks!
that pinion seems kinda high
try to line it up with a pinion on it i was told to start with a 25 tooth pinion with a 100t spur i could be wrong but that pinion sounds like a monster unless you will be at a track with a huge straight away in my eye's |
You will need to take a dremel or file and bevel the edge of the t-bar to fit that big of pinion gear.
Hope that helps |
12L4 Motor Install
In the AE instructions it tells me 35 pinion with the 100 spur for A stock motor starting point. They guys at the local track are also saying that is what they use. It is an avrage size track. I may be getting misinfomred by the guys at the track. I have not cut the tires at this time nor will I until I get my feet wet racing again and get a feel for racing again. If I need to go to a 25 that is fine but why does the AE instructions tell us to start with that if it is hard to fit? Please keep your help coming. THANKS!!!!!!!
if you have a hard time fitting a pinion i would run a smaller spur.the only time i run a 100 spur is in mod to allow for a bigger pinion for more efficient gear mesh.on my 19 turn motors i runn an 88/29.which stock motor are you running?
| All times are GMT -7. It is currently 04:01 AM. |
