-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
JoeyE 12-19-2005 11:54 PM
Originally Posted by AdrianM
We have been over this time and again. It not the winter green in Paragon that kills you it the fumes from the lacquer thinner make up most of the volume of liquid in the can.
Would it be safe to use Home Depot brand lacquer thinner instead of....?
How about suntan lotian? I see many people use that too.
BrainTeased 12-20-2005 01:43 AM
Hi guys
i have access to new CRC CKr2 kits does anyone know if these kits are suited to outdoor tracks ? i have been told by that these were run at the worlds by Marc Rheinard and Jilles Groskamp
kind regards
BT
jas 12-20-2005 05:44 AM
AE RC12L4
What you don't like about the RC12L4 when compared to others (CRC, Corally, Speedmerchant, etc.)?
The RC12L4 is pretty much the defacto choice in town, parts support is the main reason, I guess.
CypressMidWest 12-20-2005 09:58 AM
If you've got AE parts support, you pretty much have parts support for every T-bar car. Since all the cars but the Corally and older Trinity cars use AE front-ends, and all the T-bar cars use AE t-bars, you could still run pretty much any of them, as those are really the only two items that break on the cars.
What we've found locally is that the L4 chassis tends to break around the battery tray area, and many people prefer tube dampeners over the disc system included in the L4.
I personally prefer link cars, as I feel they are more adjustable, and tend to be more "free" feeling on the track.
nashrcracer 12-20-2005 11:01 AM
Actually the recall that Paragon had back in 95 was because they didn't have child proof caps because of the methyl salicylate.
http://www.cpsc.gov/cpscpub/prerel/prhtml96/96025.html
But this is only bad in heavy heavy doses. here is some good reading for your perusal
http://home.sc.rr.com/mlufaso/rc/Paragon.html
Thanks to Mike Lufaso
timmay70 12-20-2005 11:44 AM
So, how true is it that the worlds Paragon wells have dried up? Forget Iraq, bring on the hunt for more Paragon!
Is there another source for Paragon online? our local dealers seem to not be able to get any.
Mark Payne 12-20-2005 04:02 PM
More complete 1/12 Tips for you
Right... I got to where I wanted to go with the tips (for now):
My big mouth has said about 10% of what the voices in my head are saying but I cannot stand any more fiddling with cameras for a while.
So
The Complete Tweak Guide to the CRC CK 3.2R is now online with sad little videos and more pics etc.
www.12thrc.com now gets you straight in.
Cheers
Mark
Scottrik 12-20-2005 04:24 PM
Mark--that's brilliant!!
Thanks for going to all that effort.
Scottrik
mpetrich 12-20-2005 05:46 PM
Mark, thank you for the blog. The information you provided IS VERY helpful.
I really appreaciate the work you put into it.
Thanks,
Matt
factory racer 12-20-2005 06:09 PM
ok i just got into 12 scale racing...i have a CRC 3.2R bloody knife....have no clue with what to start my setup with......i actually know the front and rear ride height procedures but nothign eles...springs...front and side...damper tube lube weight???l......wat else i dont no can you guys help me out
thanks
Mike
Crashby 12-20-2005 06:44 PM
thanks
Mike
Check out the link in Mark Payne's post a couple back. Very good site!! Even though his site is about CRC cars, most of what he says can be applied to all 1/12th cars.
Great effort Mark!!
factory racer 12-20-2005 07:26 PM
wow thanks alot for showing me that link.....helped me alot
thanks
Mike
B-B 12-20-2005 08:18 PM
Rev4-Bill (aka JRXS-Bill) are you still running the sedan or just the 12th? Thats my problem, I try to run both and cant do all that well when I run both. Hope to make it to Stockton soon, Happy Holidays .
Mark Payne 12-20-2005 11:45 PM
Hi Mike
I will go on and start making handling setup notes as well as the build orinenatated stuff. I am out of time for the site now and need to have a break from it!
In the mean time, I would start with the setup below... however remember that in the UK we race with non smelly additive and our grip levels are slightly lower than yours I think. You may want to go a little stiffer in the pod area.
Front tyre: CRC purple at 45mm max, CRC Magenta if you need more turning but I would advise 43mm max on Magenta.
Rear tyre: CRC Gray at 50mm max
Damper lube: CRC Red.. the ligther one
White side spring .. red for more steering
0.020in Front spring
10 degree reactive castor block .. 5 degree for less agressive steer
No pod rise, 35 weight in the shock and the Olive Green spring
Yep... thats about it
Cheers
Mark
thanks
Mike
James35 12-21-2005 12:22 AM
Great job on the web site Mark! I appreciate it greatly. It helped to stimulate some thoughts.
If I can offer a suggestion, if you take more pics in the future, watch what your camera is deciding to autofocus on. In many of your pics, the camera didn't focus on your intended target. Switch to manual focus if possible.
Keep up the good work!
