Japan shops
Japan shops
Hi all.
Can someone give me good shops to buy from in Japan? I allready know Rainbow 10 and Champ. Rc Maniax for not sending outside Japan .
Has anyone tried direct from the manufacturer like Kawada?
I need the following parts and these are so hard to find:
Atlas: (www.miwahobby.co.jp)
MH8-500 TA-03 Front Low Friction Swing Shaft
Atomicwww.rcatomic.com)
TS-BSM2612M M2.6 x 12 Titanium Button Head Hex Socket - Machine (10 Pcs)
CSO: (http://www.cso.com.hk/htdocs/)
3003 5x10mm Ceramic Thrust Ball Bearing
HPI: (www.hpiracing.com)
87271 Serrated Flange Nut M4 (Steel/8pcs)
87266 Serrated Flange Nut M4 (Silver/4pcs)
Take Off: (http://takeoff.main.jp/)
TM-001 Magnesium Hub
TO-365BK High Traction Tape
TS-251 Titanium M3 Locknut (H4)
TS-252 Titanium M3 Locknut Thin Type (H3.3)
TS-208BK M4 Locknut Thin Type
TS-205BK M2 Locknut Aluminium
TS-201BK M3 Locknut Aluminium (H4)
TS-203BK M3 Locknut Aluminium Thin Type ( H3.3)
TS-207BK M3 Nut
TS-332BK M3x8mm Hex Socket CSK Screw
TS-333BK M3x10mm Hex Socket CSK Screw
TS-382BK M3x8mm Hex Socket Button Head Screw
TS-383BK M3x10mm Hex Socket Button Head Screw
TS-384BK M3x12mm Hex Socket Button Head Screw
Edit: (http://www.rc-edit.com/)
ED030032 Titanium Shock Shaft
Kawada: (http://www.kawadamodel.co.jp/)
FO27 Delrin Suspension Ball For F103
RN-40H 4mm Nylon Lock Nut
SK6F F103&F104 Hudy Truer Adaptor
SK-41 Suspension Ball & Motor Bearing Setter
Qtec: (http://www.multiverse.jp/QTEQ/top.html)
QT-090601 F103/F104 Left Wheel Hub
QT-090901 F104 Titanium Diff Cap
QT-090903 F104 T Bar Set
RC Square: (http://rc-square.com/)
SFC-114BK Tamiya F103 Aluminium Rear Body Mount
SFC-20G Tamiya F103 Height Adjustable Guides
STV-12P2 Teflon Piston (2 Pcs)
STV-12P3 Teflon Piston (2 Pcs)
TGE-12P-2 Teflon Piston (2 Pcs)
TGE-12P-3 Teflon Piston (2 Pcs)
SGE-14SBK Aluminium 4mm Flanged Serrated Nut
STR-335 3x35mm Hex Countersunk Screw
FAW-308B 3x8 Hex Flanged Buttonhead Screw (4 Pcs)
Xenon: (http://www.xenon.ne.jp/)
OPT-0020 1/12 Front Springs .425
OPT-0021 1/12 Front Springs.450
OPT-0022 1/12 Front Springs.475
OPT-0023 1/12 Front Springs.500
OPT-0024 1/12 Front Springs.525
OPT-0025 1/12 Front Springs.550
Morotech: (http://www.morotech.jp/)
T-Cone F104
TS-207BK M3 Nut
T-Cone F104
RC Champ can order anything from Kawada for you. That's where I get my stuff from.
if you are in Japan,Akihabara , where RC Champ is, within a two km radius of the train station there are 4 shops, i cannot remeber there names but they are there, now on the image these are approx where they are
jason
jason
I mean online shops becouse not leavin' Belgium very soon.
You can try www.super-rc-com . They have lots other stuff than those listed - just drop them an email (English is fine) to ask.
thanks for the info I will have a visit in Japan in the summer. I will visit Akihabara then. heard they got alot of Manga/Animé and now RC! OMG, cant be better :P haha
www.andrefossto.wordpress.com
Beware : rc champ owners don't like small children in the shop.
On the way back from rc champ to akihabara station, you will walk through a big street. On that street you'll find manga anime stores, coffee shops with waitresses you can pretend to cry while she is feeding you, luggage stores, electronics stores, etc.
Thanks, more shops?
Too bad funabashi city is quite far from tokyo, and the shop location is not within comfortable walking distance from funabashi train station.
The best shopping experience with pro s futaba is to send them e-mail along with your shopping list. The shop keeper will e-mail back the next day the price and availability along with your purchase order confirmation. If you agree, you sign the purchase order confirmation + give them information how are you going to pay it.
