Schumacher Corner
weekend
Not a bad weekend at the northwest carpet champs this weekend. Tqed expert stock and won the main on saturday and tqed and won 10.5 also.
Sunday was a little worse with my driving being off but the car was dialed .I ended up second in stock and third in 10.5 but got the overall in stock and second in 10.5.Car was near perfect all weekend. side note i ran the lowered towers with hpi springs all the way around and had no problems.
on rubber..thanks for the update and good job as well!
Good job Aaron.
No out of 70 entries i had the only schumacher there .I ran the regular shock tower the first two rounds and then changed it to lower the front of the body a little to get it down on the carpet. Another good thing if you run the lower tower with the stock bottoms it limits the up travel almost perfect which is something i had not fixed on the car.Only thing is you would have to run rps cause the diameter is just small enough for adjustment without changing shock bottoms.
Skiddins
Speed passion for sale product is expected sometime between late this week and next week.
I'll be getting the part #'s into the system this week, so look for them up on the website Fri/Mon or give us a call/email starting Fri for ordering.
Coming in:
SP GT ESC (W/Programming box - NICE!)
SP Feigao ESC (W/Programming box - NICE!)
SP 2.5t motor
SP 3.5t motor
SP 4.5t motor
SP 5.5t Motor
SP 6.5t Motor
SP 10.5t motor
SP 13.5t Motor
ALL SP Tuning rotors
SP motor accessories - sensor cables, sensor units, motor connectors, etc.
Coming in:
SP 2.5t motor
SP 3.5t motor
SP 4.5t motor
SP 5.5t Motor
SP 6.5t Motor
SP 10.5t motor
SP 13.5t Motor
Anybody using o-rings or foamies in the shock bladders?
Super Moderator
any one have,
an Mi2,Mi3 one way,or diff for sale..
Super Moderator
has anyone tried a diff in the front in asphalt(with the mi3) ? or will the car push alot coming out of the corner?
I haven't tried it but to be honest, I wouldn't bother. Just like you said, it'll push middle to exit, just like they do in any other car on asphalt.
Super Moderator
spur
I got a 90 spur to fit wth ezzzzzz 90/37 4.37 fdr 38 is 4.26 39 is 4.15 I will start at 4.37 and see.....
