Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-13-2007, 07:00 PM
  #20176
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by CountryHick
Just finished building it. Does anyone know what ABEC rating the kit bearings are?
Nice build and nice camera work... you can see dust specks on the motor Wait... that's my monitor Can I ask what camera you are using?
MikeR is offline
Old 06-13-2007, 07:15 PM
  #20177
Trader Rating: 26 (100%+)
It's a sony "a100". It's more to do with the lighting than the camera.
http://www.sonystyle.com/webapp/wcs/...play?jspStoreDhttp://www.sonystyle.com/webapp/wcs/...dkey=ClickInfo
CountryHick is offline
Old 06-13-2007, 07:16 PM
  #20178
sorry about the length of that link.
Old 06-13-2007, 07:21 PM
  #20179
Trader Rating: 19 (100%+)
what is that on ur wires looks nice
teammidget lilB is offline
Old 06-13-2007, 07:23 PM
  #20180
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
lilb you can get that for the wires at skycraft in winter park
Marcos.J is offline
Old 06-13-2007, 07:27 PM
  #20181
AdrianM's Avatar
Country - The bearings are not ABEC rated. They are however, built to Schumacher specs and are really darned nice.
Here is a bit of bearing info that applies to this question...
High ABEC rated bearings have tight tolerances. The better the rating the tighter the tolerances and the better the internal surface finishes are. This is good and bad. When new can clean expensive ABEC bearings are great. Unfortunatly after a few runs they can get dirty and the tight tolerances work against you. It is much more important to keep a high grade bearing clean in order for it to be free.
Starting with the Mi2EC Schumacher has been buying bearings built to thier specs. They have slightly looser tolerances but very fine surface finishes on the bearing races and very good quality balls. They also come oiled, not greased, so they are free and fast right out of the box.
The kit bearings are so good most of the factory team drivers use the stock bearings.
If you want the best possible bearings for you Mi3 the Schumacher Ceramic bearing set uses the same inner and outer races at the kit bearings but use silicon nitride ceramic balls for ultimate smoothness and durability.
AdrianM is offline
Old 06-13-2007, 07:59 PM
  #20182
Thanks Adrian.
Old 06-13-2007, 09:25 PM
  #20183
IslandBwoy's Avatar
Are any of you Floridians going to MinReg? I'll like to the Mi3 in action.
IslandBwoy is offline
Old 06-13-2007, 09:51 PM
  #20184
Super Moderator
Marcos.J's Avatar
isnt Minreng in Florida??
Marcos.J is offline
Old 06-13-2007, 10:46 PM
  #20185
JayBee's Avatar
Trader Rating: 31 (100%+)
CountryHick-
That wiring job is nice! Makes me want to rush wiring my Brushless MI3
JayBee is offline
Old 06-13-2007, 10:47 PM
  #20186
scott_g's Avatar
That is a great build. You rock Hick! Can't wait to see you go after Tones over the next few months.
scott_g is offline
Old 06-14-2007, 08:09 AM
  #20187
yoyoyo Randy, look forward to catching up with you at vegas!!
hows things with the car , what did you use to dye you white plastic parts??
thanks jimmy
jimmy..maddison is offline
Old 06-14-2007, 08:52 AM
  #20188
SlamMan's Avatar
Super clean install. Nice!
What is that stuff on the wires? Can it be found on line somewhere?
SlamMan is offline
Old 06-14-2007, 01:03 PM
  #20189
Sigearhead's Avatar
Trader Rating: 74 (100%+)
I was thinking the same thing. I would love to wire my car like that! It looks pretty sweet!
Sigearhead is offline
Old 06-14-2007, 01:06 PM
  #20190
Default Wire cover
I"m sure you can find this stuff in the States somwhere, but because I live in Australia I got mine here.
http://www.techflex.biz/index.html
