Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 08-16-2005, 10:29 AM
  #10666
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by Conrad
I've used plastic driveshafts since the car came out and never had any problems with them, i've never used a spool or one way so thats probably the reason but certainly 27t stock right thru to 10t mod has never been a problem for the plastic ones
I was silly for using the plastic shafts with a spool but didn't have any hopups yet as this was the first time I ran the car. They will not hold up to a spool.
RKeasler is offline
Old 08-16-2005, 02:41 PM
  #10667
protc3's Avatar
Originally Posted by P-DUB
WOW man...That's awesome!!! Now check out www.pdubracing.com
NICE!!
protc3 is offline
Old 08-17-2005, 05:22 AM
  #10668
IslandBwoy's Avatar
Anyone have contact info for Padilla? He has some fast body clips i want to get off of him :-)
IslandBwoy is offline
Old 08-17-2005, 06:27 AM
  #10669
A Ilievski's Avatar
Trader Rating: 39 (100%+)
hi guys on this mi2 http://www.pdubracing.com/images/bmi_mi2.jpg how can i change my rear body posts the stay on the shock towers, or is that what happens with the lower shock towers
A Ilievski is offline
Old 08-17-2005, 06:30 AM
  #10670
TimPotter's Avatar
Trader Rating: 15 (100%+)
In that paticular picture, those are BMI shock towers. The BMI towers have a mount built into them so you can use Xray rear body mounts.
TimPotter is offline
Old 08-17-2005, 06:41 AM
  #10671
tonyp126's Avatar
No body clips for you
[email protected]
tonyp126 is offline
Old 08-17-2005, 07:02 AM
  #10672
STLNLST's Avatar
Trader Rating: 32 (100%+)
AE mounts work as well...
STLNLST is offline
Old 08-17-2005, 07:04 AM
  #10673
RKeasler's Avatar
If I remember correctly, 1mm spacer = 1.77 deg
P-DUB when you go low roll in the front you said use a strap do you have a picture that better shows what you mean?
Rod
RKeasler is offline
Old 08-17-2005, 12:12 PM
  #10674
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I'll post a pic up tonight but you're basically just cutting a riser plate and bolting the top part on top of the pivot blocks to add support.
Jon Kerr is offline
Old 08-17-2005, 05:31 PM
  #10675
Jon Kerr's Avatar
This should explain it
Jon Kerr is offline
Old 08-17-2005, 05:54 PM
  #10676
P-DUB's Avatar
Thanks Jon....I really like the outdrive savers
P-DUB is offline
Old 08-17-2005, 06:06 PM
  #10677
cornerspeed's Avatar
Sorry Jon, but I have to take credit for the outdrive savers.
cornerspeed is offline
Old 08-17-2005, 06:22 PM
  #10678
King-G's Avatar
Those red shims are ghastly!
King-G is offline
Old 08-17-2005, 07:00 PM
  #10679
Iain's Avatar
Yeah, some nice purple ones would fit nicely!!!!
Iain is offline
Old 08-17-2005, 07:12 PM
  #10680
AdrianM's Avatar
Since the shims are available in 7 colors and 7 sizes some industrious racers are color coding the sizes
Either that or we were out if that particular size in Purple when Jon ordered them...lol!
AdrianM is offline
