Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 05-20-2005, 10:58 AM
  #9706
speedxl's Avatar
Default Re: Reedy Race!
Originally posted by Jon Kerr
I'm getting excited for the race. PW, Adrian, when are you guys getting in? Wednesday night?
Jon I am getting in on tuesday night about how far is lax to laguna hills 30 to 40 minutes? I hate flying so I picked the flight into lax because it was none stop! Dang I hate flying.
speedxl is offline
Old 05-20-2005, 11:00 AM
  #9707
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I'm not a big flight fan myself. I'm not too sure how far that drive is. I'm in San Diego. It's about a 1 1/2 drive for me to the track.
Jon Kerr is offline
Old 05-20-2005, 11:21 AM
  #9708
PW
PW's Avatar
No Adrian, just me I get in around 1:30pm Wednesday.
PW is offline
Old 05-20-2005, 11:29 AM
  #9709
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Re: Re: Reedy Race!
Good luck Paul
Marcos.J is offline
Old 05-20-2005, 11:57 AM
  #9710
Jon Kerr's Avatar
No Adrian? Didn't want to leve Troy there all by himself? Is Teemu going to make it this year?
Jon Kerr is offline
Old 05-20-2005, 12:45 PM
  #9711
Tony Rivas's Avatar
Trader Rating: 56 (100%+)
[QUOTE]Originally posted by the shoe
Troy by the way i tried to download your set-up off gearchart and all i get is a blank page??????No love for Troy is right!!!!!!!! LOL [/QUOT
Tony Rivas is offline
Old 05-20-2005, 12:46 PM
  #9712
Tony Rivas's Avatar
Default Re: turbodog set-up
the shoe hey send me your e-mail
Old 05-20-2005, 01:27 PM
  #9713
STLNLST's Avatar
Trader Rating: 32 (100%+)
I think Mo and I will get in around 4pm. We are equally excited about this race. Can't wait to just put the car down and have some fun. Good luck to everyone and I'll see ya when I see ya!
STLNLST is offline
Old 05-21-2005, 06:52 PM
  #9714
speedxl's Avatar
I am flying in tuesday evening around 6:30pm. That way I'll have wenesday to relax and check out the area!
By the way are there any hobby stores in the laguna hills nieghborhood!
speedxl is offline
Old 05-22-2005, 10:43 PM
  #9715
Jon Kerr's Avatar
Kind of sucked not be ing able to get on here for a full day. Oh well, gave me time to finsh getting the Reedy car ready. I decided to install a fan on the motor after talking to Sean Cochran last weekend about how much they really help when they're done right. Here's how set mine up. The wiring could have been neater I guess.
Jon Kerr is offline
Old 05-22-2005, 11:05 PM
  #9716
ottoman's Avatar
Does your fan spin when you power it up? Every time I mounted a fan that close to the can it wouldn't spin... I guess due to the magnetic force from the motor... anyway I always had to move them about a 1/4 inch away from the can to make them work. This was back in the day when we ran TC3's and I think the fan was positioned more between the can mags than your seems to be.... maybe that would make a difference
ottoman is offline
Old 05-22-2005, 11:20 PM
  #9717
Jon Kerr's Avatar
It didn't at first. I couldn't figure it out at first. It worked out of the car but not in it. Then I figured the motor was probably messing with it. I moved it back just a touch and it worked. I really didn't want to try and move the ESC forward any more because of the servo and ESC wires. I may still do it though just in case.
Jon Kerr is offline
Old 05-23-2005, 05:48 AM
  #9718
speedxl's Avatar
jon you might consider making a lexan mount for the fan extending out from the chassis with the fan pointed in an angle to the endbell! Something like a nerf wing! Also whats wrong with mounting it behind the motor towards the rear.
speedxl is offline
Old 05-23-2005, 07:34 AM
  #9719
Jon Kerr's Avatar
I thought about monting it angled like that. I think mounting it behind the motor, the wind coming under the car would try and blow the fan the wrong way and not let it work properly. This way it's using the incoming wind to aid it.
Jon Kerr is offline
Old 05-23-2005, 08:06 AM
  #9720
speedxl's Avatar
There isnt as much air moving thru the body as you think, atleast to impede the air volume from the fan. Take the fan of and mount it were you can blow against it. If it stops then you might have a problem. Those little fans are stronger then you think wired straight to the speedo like you have!
speedxl is offline
