Schumacher Corner
#8116
I use the annodized tamiya threaded shock mount, all that is required then is a 10mm Ti screw for the ultimate lightweight shock mount....easy shock position changes to boot!..
For the lower mount I'm using the flourine coated Tamiya ballstud, with the tamiya ballcup.
#8117
Mad props to Weylin Rose for his awesome performance this past weekend finishing 2nd place behind Chris Tosolini. This was Weylin's first big race in the mod class on foam tires...Keep up the great work
#8118
what race??? where can we get results?
#8119
#8122
raincity race
was this a aspahlt foam race, or a carpet foam? I only saw pic's of a outdoor track.?? Good race for Weylin, wtg!
#8125
Mission Setup Sheets Anyone
Hey I'm on gearchart and i cant find any setup sheets for the origal mission. You guys have any that i can use? Outdoor, small track, medim traction would be prefered.
Thanks,
R.
Thanks,
R.
#8126
Ive had my Mi2 for a couple of weeks now and it has just kept getting faster every run. Wich is great considering I was faster with it than my TC3 after only 2 runs without any practice. I switched cars in the middle of a big race as I could not get my TC3 to carry any speed in the corners. I have been getting alot of help from the Team Schumacher guys at the local tracks wich has increased the learning curve tremendously. Very impresive so far.
I also want to thank Schumacher for helping sponsor The Midwest Touring Series. Its the first year of the series and with the help of Schumacher and others is looking to be staying around for many years to come.
Thanks Adrian,
Speedie
Thanks Adrian,
Speedie
#8128
Mi2's took home the wins in both touring classes stock foam and stock rubber.
