Schumacher Corner
#5492
I feel ya shoe, I'm pushing so hard to get the cars here ASAP!!!!
I truly think its really awesome that they at least got some cars to us for the average racer going to the carpet nats....No way any other car manufacture would have done that
ottoman....I assume you are getting your car from KT Hobbies? KT Hobbies will have a lot of parts in stock at the same time the car arrives and I will also have parts with me at the carpet nats.
WOW, good news about the track RB & Ray
#5494
Finally got time to start assembling my Mi2 yesterday. Some things I've noticed so far:
-still have to remove the thin spacer behind the wheel hex cone washer, otherwise the bearings will bind
-had to file rear lower arms to fit the hub carrier pivot pin e-clips (pin a bit 2 short/arm 2 fat)
Have to continue today... I can't wait to drive it. Any setup advice for carpet/rubber would be useful, since I won't get any practice before the first race It has to work better than my Mission the moment it touches the carpet
#5495
Originally posted by EAMotorsports
Hey Ray/Rob could you make sure that they mark a spot off for me and Jason Lutz to pit for the nats? Also Putnam is coming and needs somewhere also...close to Dieter he said!! He said the better the spot the more HP he could build....LOL
3 weeks...cant hardly wait!!
ea
ea
#5496
Originally posted by rayhuang
Yeah ottoman-if you break now-you either missed the apex by 4' or got hacked!! Track designs are still fast and challenging, but with 8' long padded flappers hung loose-its your fault if you break!!!
Yup-all flappers are 8'x4" long pieces of HDPE with a 1/4 foam padding behind. They are awesome-for a flapper!!
Ray
Ray
Blake
#5497
olev....Shoot me an e-mail and I will get you some setups for rubber tire. Call Schumacher to get a new set of hinge-pins under warranty [email protected]
#5498
if the weather stays good for tomorrow it's going to be fun at speedworld. The pro4 will be there along with a couple of new Yokomo's and E.J. might be running the new tamiya (if he has it yet) and then Tessa will be rolled off of the truck....LOL
PW- weather permitting I'll have some mod feed back for you this weekend. Thanks again for the set up.
#5500
Hey guys, I was working on my MI2 and I thought I would throw up a pic of the front brace Paul was talking about for running without the roll center plates installed. I'll post a few more also.
You can see it on top of the front forward arm mounts. There are two purple lock nuts holding it in place.
#5505
Batterytray
Is it correct that in the Mi2 Carbon kit there is a S1 batterytray?
I thought that when you buy a Carbon kit there are only carbon parts in the kit and no S1 parts!
