Schumacher Corner
#5221
PW, have you got the part number for the Ti-R upper suspension mounts?
Cheerio Gavin
Cheerio Gavin
#5223
Snowbirds Help!
Gonna run my Mission SST in the Oval 6-Cell 19-Turn class at the Snowbirds. Since this will be my first time on carpet with my Mission sure could use some help:
Tires - Springs - Oil - Gearing
Help please
Bob
Help please
Bob
#5225
Thanks guys, the state race was a great start to the 2004 Florida State Series for Schumacher!!!!
amusicwiz....Tony P didn't have that setup anymore and he doesn't really remember what he ran. I hope someone can help you out with this, but all I can recommend is to start out with a good carpet setup (road-course) and then work on it from there.
#5226
Hello!
What is the weight difference between Mi2 S1 and Mi2 Carbon?
/AN
/AN
#5227
hey do you know were can i buy one from which hobby shop
#5228
Paul:
Thanks for trying! Will hope someone else will jump in with some input.
Bob
Bob
#5229
An:
The S1 is a fiberglass type material that is not quite as stiff as the carbon fiber (and doesn't mave that carbon fiber look). It, however doesn't cost as much as carbon fiber, so that kit is usually not as expensive as the C/F kit. Other than that (which ends up being the chassis, top plate and shock mounts front and rear) the cars are identical. Hope that helps...
#5234
WOW....Westside in Da'hizouse!!!!
