Schumacher Corner
Hey guys,
It's been a while since i had to take a break from rc. I am trying to figure out what gear ratio i need to run in my Mi3 for the 540 stock class (ie running the 540 Johnson silver can motor) Will also be running lipo batteries.
Currently i have 31/70 in the car, is this ok or should i be using a different ratio? What FDR?
Thanks.
Thanks.
Nevermind finally found my old post, seems 31/70 is what i should be running.
Hey guys,
Thanks.
Thanks.
Oh ok, well i was told before that an FDR of 4 - 4.05 was the way to go for the silver can.
So trying to search for front spool cvd chatter,tried exp and DR on my radio, and still chatters alot.. only thing I havent done is ca 2mm shim to my knuckle
anyone have any other ideas?
I have been told by the guys that have done it that it works extremely well.
Skiddins
Super Moderator
What are the blue orings that come in the shock seal pack for the mi3 used for?
One pack comes with 2 clear orings & 4 blue orings
On another note I'm thinking of picking up a brand new SpeedPassion GT v1.1 cheap and just wanted to know if there is any upgrade software available for it? Also is it good enough to power a 5.5 brushless motor?
Cheers
Adrian
R/C Tech Elite Member
That sounds like an awesome idea, what is mi3's length of driveshaft? and what other mod do we need to make it work? just file away the spool slot to fit xray's blade?
Also whats the strongest drive shaft blades to run in the front of an mi3 with a spool, mine apear to be cracked. (do the newer ones fit?)
and is thier a way to tell the rear toe with out a setup station, like mm of spacers = degrees of toe?
