Schumacher Corner
#2582
Team EAM
Stock TC
6 RON ATOMIC 206 |( 3) 21/5:14.39 |( 3) 21/5:12.01
6 ALEX LOPEZ 99 |( 4) 20/5:01.55 |( 2) 21/5:11.29
7 TIMMY HEISER 124 |( 2) 21/5:14.26 |( 5) 21/5:13.23
11 DUSTIN EVANS 157 |( 7) 20/5:02.74 |( 4) 21/5:12.60
11 MICHAEL BRUCE 195 |( 0) 21/5:13.29 |(11) 20/5:03.05
13 CHRIS MARSH 81 |( 5) 20/5:02.33 |( 8) 20/5:00.07
20 JADE KURTCHI 109 |(10) 20/5:04.27 |(10) 20/5:01.04
21 ERIC SANCHEZ 21 |(15) 20/5:07.82 |( 6) 21/5:13.59
21 BRAD JOHNSON 113 |( 8) 20/5:03.18 |(13) 20/5:04.28
23 CHRIS PERRY 63 |(11) 20/5:04.65 |(12) 20/5:03.39
Mod Touring car
0 BARRY BAKER 174 |( 0) 23/5:01.63 |( 0) 23/5:02.69
5 BRIAN KINWALD 107 |( 3) 23/5:06.15 |( 2) 23/5:03.05
6 MARK PAVIDIS 55 |( 2) 23/5:04.72 |( 4) 23/5:03.95
7 PAUL LEMIEUX 94 |( 4) 23/5:06.23 |( 3) 23/5:03.88
10 TRAVIS AMEZCUA 202 |( 5) 23/5:06.27 |( 5) 23/5:04.95
13 MIKE BLACKSTOCK 184 |( 6) 23/5:07.06 |( 7) 23/5:06.37
13 TODD HODGE 128 |( 7) 23/5:07.74 |( 6) 23/5:05.97
18 GREG HODAPP 127 |( 9) 23/5:10.31 |( 9) 23/5:07.21
19 BILLY EASTON 158 |(11) 23/5:10.85 |( 8) 23/5:06.47
24 RALPH BURCH 197 |(14) 22/5:01.78 |(10) 23/5:07.78
Big Dog...that was TJ Domark (I think thats his last name).
eric a
Mod Touring car
eric a
#2583
Team EAM
19 turn
0 RON ATOMIC 207 |( 0) 21/5:06.73 |( 0) 21/5:02.11
6 JADE KURTCHI 110 |( 2) 21/5:09.03 |( 4) 21/5:09.98
10 SCOTTY ERNST 154 |( 3) 21/5:10.26 |( 7) 21/5:13.26
12 MICHAEL BRUCE 212 |( 9) 20/5:05.57 |( 3) 21/5:08.73
15 JASON WILLENER 9 |(10) 20/5:05.63 |( 5) 21/5:10.20
16 RAFAEL ANGULO 204 |( 4) 21/5:12.12 |(12) 20/5:05.44
21 HECTOR GARCIA 134 |(11) 20/5:06.79 |(10) 20/5:02.74
22 COREY MCCARTNEY 77 |( 8) 20/5:02.68 |(14) 20/5:07.69
23 PAIGE OMEARA 73 |( 7) 20/5:01.77 |(16) 20/5:08.63
28 KEN PEPE 61 |(15) 19/5:00.64 |(13) 20/5:06.92
#2584
Come on Paul!
#2585
Trader Rating: 32 (100%+)
Hey word on the street is that Ron Atomic is a full Hudy driver now anyone else know if this is true?
Keep up the good work Alex and Timmy lets see how the rest of it finnishes out.
#2586
EA motorsports....I dont think it was Domark he's only an oval racer. It could have been TJ Bradley the guy who won snowbirds.
#2588
More like the TJ right-of-way...
That kinda sucked for Ron- I know some people think he's well, ummm you know... but you just have to get to know him. I thought the same thing when I met him. Turns out I always enjoy hanging out with him. Just goes to show- don't always judge a book by it's cover.
#2590
Never mind, found it...
Mains at the Nationals:
Race # 1 -- TOURING CAR STOCK - A MAIN --
qual pts:laps/time name
1 0:42/10:13.1 STEVE WEISS
2 2:42/10:09.4 ALEX LOPEZ
3 5:42/10:19.1 RON ATOMIC
4 5:42/10:23.7 MICHAEL BRUCE
5 7:42/10:27.5 TIMMY HEISER
6 9:41/10:09.8 SCOTTY ERNST
7 11:41/10:15.3 DUSTIN EVANS
8 13:40/10:02.4 CHRIS MARSH
9 13:42/10:27.5 COREY MCCARTNEY
10 14:42/10:27.2 ERIC SANCHEZ
Race # 2 -- TOURING CAR - MOD - A MAIN --
1 0:46/10:04.3 BARRY BAKER
2 2:47/10:17.9 MARK PAVIDIS
3 4:46/10:03.3 BRIAN KINWALD
4 7:46/10:10.1 PAUL LEMIEUX
5 7:46/10:06.0 BILLY EASTON
6 8:46/10:06.6 TRAVIS AMEZCUA
7 10:46/10:12.2 TODD HODGE
8 12:46/10:15.2 MIKE BLACKSTOCK
9 13:46/10:10.9 CHRIS TOSLINI
10 13:46/10:08.9 GREG HODAPP
#2591
Darkseid,
Do you still run your X-ray, if not why. I'm thinking about buying the Evo2. I have my Mission working really good. I'm definetly faster than I was with my Losi, but their are a few things about the Mission I don't like. Such as:
The material Schumacher uses is very soft and bends very easy, I'm not sure if it's steel or what. I'm replacing a lot of parts.
Some of the adjustments are a little time consuming to make, like the caster and wheel base adjustments.
I feel I wont have the same problems with the X-ray. What do you think??
#2592
Ottoman.....Sorry I missed the last part of your post. E-mail me and I will send you my latest setup for rubber tire carpet, my car worked soooo well last time I ran it. Email [email protected]
#2593
rc fiend...are those you're only complaints with the mission?..
you should rethink swapping over if they are..
the castor clips can be obtained from schumacher to make the castor adjustments even uicker, right now I reckon I can do it in 5 mins...with the standard shims, so i feel its a non issue, and certainly a ton quicker than the tc3, Losi and any other car using c/hubs
the wheelbase adjustment takes me even less time?......remove the single screw holding the rear or front pin holders, slide out the pin slightly, remove teh shim and replace in desired order, and screw it back in..takes like 2 mins per side tops!..
as for durability...I have bent a couple of upper arms on a tight indoor track with unforgiving barriers, which love to grab ya by the nuts....but on our outdoor track I have only ever broken 1 arm..after a massive tap, which put me head on into a wall at the end of the straight, all that broke was the lower front arm...!
I have previously driven for Corally in Austrakia, and found that car to be of similar durability, but it would bend hingepins like butter!..the c4.1 is regarded as being stronger than the xray....as the serpent arms are beefier!
what exactly are you bending on your mission?..the outer king pins?..these can bend in a hard impact, but are cheap and easy to replace, I feel these help to prevent damage from any other components..
seriously though, the shcumachers engineering is top notch, they have evolved the cars design to this level over a period of years of refinement..
#2595
Originally Posted By King - G rc fiend...are those you're only complaints with the mission?..
As I said other than those items I really like the car, man is it fast and I don't even think I have come close to the perfect setup yet.
