Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 10-26-2007, 12:08 PM
  #22606
Originally Posted by Ron Goetter
everything but the springs... I found that my car was tweaking thats why I put the stiff top deck on that got ride of my tweaking problem... I wanted to try the stiff flex top deck but I don't have one...
Are u coming tomorrow?
That is wierd that it was tweaking. That track is completely different kind of asphalt to figure out a good setup. Super high bite. My car ran super flat. I decided to go to Mimi's to run the 1/12th on carpet again. 2 weeks to the regionals. I wish I had the extra cash for batteries for the Mi3.
SRW141 is offline
Old 10-26-2007, 12:25 PM
  #22607
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
I should be at mimi's for regionals.. c-ya then
Ron Goetter is offline
Old 10-26-2007, 12:54 PM
  #22608
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Start charging for Karen's cookies. You'll be able to buy 20 packs after 1 race weekend!
KyLayfield is offline
Old 10-26-2007, 04:23 PM
  #22609
Trader Rating: 17 (100%+)
Where can I find the 96T spur and the P-dub bumper...? Most likely...I need that P-dub bumper baddddddddddddd (oh, yeah, is for my Mi3.)
Solara is offline
Old 10-26-2007, 05:49 PM
  #22610
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
i've been told they've been shipped, so we should have them in stock and ready to ship early next week.
And for the spur we've had them for about a month or 2
abailey21 is offline
Old 10-26-2007, 05:53 PM
  #22611
dawgmeat's Avatar
abailey21
any pics of the new bulk heads?
dawgmeat is offline
Old 10-26-2007, 05:54 PM
  #22612
Skiddins's Avatar
Originally Posted by Customworksking
Has anyone ran the foam towers on rubber tires ? or both towers and chassis..
I have the 2.5mm chassis and the lowered shock towers and run rubber/asphalt.
The car does seem to handle well, and clipping the corner markers does less to upset the car now.
One of the UK Mod drivers has commented on the fact his laptimes got better with the 2.5mm chassis (this happened to be rubber/carpet but I believe it still applies). He was running a standard chassis and the 2.5mm back to back.
The thicker chassis was simply faster.
Skiddins
Skiddins is offline
Old 10-26-2007, 06:17 PM
  #22613
abailey21's Avatar
Not mounted, but i can get some unmounted on Monday
I had a kit with them installed but thats on a plane back to England with Robin
Wish you would have asked this morning man
Originally Posted by dawgmeat
abailey21
Old 10-26-2007, 07:16 PM
  #22614
yokemad's Avatar
@Damian
How about On Rubber/Carpet? Have you Tried Lower Shock Towers on Carpet with and with out 2.5 Chassis??
Does it necessary to go for 2.5 Chassis On Rubber/Carpet??
Last one How much are the Lower Shock Towers in UK
Cheers
yokemad is offline
Old 10-27-2007, 01:33 AM
  #22615
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Adam were you able to ship my order today(ie-yesterday)?
JayBee is offline
Old 10-27-2007, 06:20 AM
  #22616
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Ran rubber tire carpet last night on the old hook and loop style carpet and man what a blast it was. Ran my asphalt setup I had on from the Region 2 asphalt Regionals from back in August. Car was pretty loose at first but after 2 runs the car came in great with CS 27's on the car. All I did from my asphalt setup was to take off the rear swaybar, added one more shim to take my toe in from 2 degree to 2 1/2 a side in the rear and I add orings to my toplate to give the car more flex and the car was really nice to drive overall.
It was very tought running against lipo's and brushless motors with my stock motors and IB packs but managed to TQ and take the win. My laptimes where very consistant and did run the fastest lap of the night but being smooth. Another thing that was tough is they run 6 minute heats and mains. Never done that before but it was cool.
All in all great day for my Schumacher MI3 as it was the only one at that track so maybe we can get a few more rolling up at Altoona Raceway.
wyd is offline
Old 10-27-2007, 08:07 AM
  #22617
Skiddins's Avatar
Originally Posted by yokemad
@Damian
Cheers
I haven't yet had the chance to try the shock towers etc on carpet, I should get the chance next weekend.
Arguably it isn't necessary to get any of this stuff but I felt it did help the car on asphalt that didn't have much grip, so I would have thought it would be even better on carpet.
The feeling from a couple of the guys (far more experienced decent National drivers..unlike me) was that changes to the suspension were not having any effect on the handling problems they were trying to solve no matter what they did (this was on carpet/rubber), they put this down to the possibility that the 2mm chassis with all the holes etc 'might' be a bit too soft so grip was being gained through chassis flex, not suspension movement.
In case your wondering, I will be buying another 2.5mm chassis for my brushed car (I still use the standard top decks at the moment).
The lower towers are £8.50 before VAT.
If you think any of these bits might help you, try the shock towers first as they are far cheaper than the 2.5mm chassis
Skiddins
Skiddins is offline
Old 10-27-2007, 08:25 AM
  #22618
yokemad's Avatar
many Thanx Dude
you're doing really well...I follow your results
yokemad is offline
Old 10-27-2007, 09:00 AM
  #22619
abailey21's Avatar
Yeah it went out last night
Old 10-27-2007, 10:12 AM
  #22620
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default u
man Adam U r on your JOB great work/support ...I guess u will be calling me Monday for my order...Kevin
Customworksking is offline
