Schumacher Corner
Originally Posted by AdrianM
The fixed layshaft is a hardened steel piece 5mm in diameter with an 8mm square foot at its base. It is about 20mm long. This piece is screws to an 8mm thick bulkhead.
This assembly has been tested for over a year. Team drivers have run it on modified Mi2EC's and Mi3 Prototypes with ZERO issues.
The R&D department has done some pretty evil non track teasting on the Mi3 layshaft setup. You have nothing to worry about...trust me
89 i think?
Yes it will be an 89T 48P gear.
Regional Moderator
I'm not worried about what spur comes with the kit as long as those 114t 64p spurs are availible at the same time as the kit.
114T, 116T and 118T 64DP gears will probably be here before the Mi3.
I hope someone is making up an 'editable' blank PDF setup sheet for the new car.
Please try to keep it fairly simple like the other Schuey sheets, not like the Cyclone etc
Skiddins
Skiddins
anyone got the pt number for all the different spurs? thanks stephen
Super Moderator
Regional Moderator
Will you guys give us a heads up as to when that stuff is actually availible?
I'm not asking for you to give a future date or anything like that. I mean like, once things like the spur(and...oh...say...the battery strap ) become availible before the car, will you guys come on and say..."btw guys you can pick this stuff up now".
Originally Posted by Marcos.J
Regional Moderator
U3164 116T 64dp CNC Spur Gear - Mi-3
U3165 118T 64dp CNC Spur Gear - Mi-3
A few people have made comment about a MI3 exploded diagram? Anyone have a link? Thanks!!!
Super Moderator
R/C Tech Elite Member
Just wondering, is that the only exploded view available, or would there happen to be one a little larger/clearer so I can get a better look at the part #'s?
