Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 06-28-2006, 10:25 AM
  #15316
I use the JR 8450 in my Mi2EC. I also think WYD uses the 8450 also.
SRW141 is offline
Old 06-28-2006, 11:01 AM
  #15317
Here's a tip:
If you take the alu drive shaft wheelhex and the to spacers from the old Mi2 and put it on the EC, you increase the track width by 2mm in each side. Or said in another way. You go from 190mm to 194mm.
Jan Larsen is offline
Old 06-28-2006, 11:03 AM
  #15318
Trader Rating: 22 (100%+)
KO Digital in my car.
Bob Barry is offline
Old 06-28-2006, 11:11 AM
  #15319
AdrianM's Avatar
Originally Posted by Jan Larsen
Here's a tip:
A standard Mi2EC is 186mm wide with no spacers. The old Mi2 hexes are 1.5mm wider than the EC hexes. If you run the old axles and hexes you will have a 189mm wide car.
The only way I see your car being 194mm is if you used old Mi2 rear hubs on the EC. That would put you over 190mm in the rear.
AdrianM is offline
Old 06-28-2006, 11:14 AM
  #15320
Ok, I admit, didn't check the current track width, the 190 was just as a reference. But i'm using the standard EC axles with the old hexes. Works very well and widens the car 3-4mm.
Old 06-28-2006, 01:15 PM
  #15321
STLNLST's Avatar
Trader Rating: 32 (100%+)
I'm running the old axles and steel drive shafts with the EC alum hexes and my car isn't wider than 190mm. Had no problems going thru tech at the Reedy or the asphalt nats.
STLNLST is offline
Old 06-28-2006, 01:51 PM
  #15322
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I also use the JR 8450 in my car.
wyd is offline
Old 06-28-2006, 05:17 PM
  #15323
kyle "hitawall"'s Avatar
I just Finised putting my MI2EC togather. It went together really well. So far I am really impressed with the car. i can't wait to run it.
kyle "hitawall" is offline
Old 06-28-2006, 05:25 PM
  #15324
It is an awesome car. You will love it.
SRW141 is offline
Old 06-28-2006, 07:23 PM
  #15325
wyd
Tech Legend
wyd's Avatar
Very nice car. Minereally works well for me and overall pretty easy to work on. Another nice feature is this forum. Lots of guys on here that can help you out. PW and Adrian at Schumacher are very helpful.
wyd is offline
Old 06-29-2006, 06:52 AM
  #15326
Sanabria's Avatar
You'll like it a lot Kyle. How the tides change...Lil B, Dave and now you all in less than a week. There will be a Schumacher Battalion at the remaining FSEARA races.
Sanabria is offline
Old 06-29-2006, 07:26 AM
  #15327
IslandBwoy's Avatar
Great now i'm going to have to get a new car
IslandBwoy is offline
Old 06-29-2006, 04:39 PM
  #15328
IslandBwoy's Avatar
Question: How do you build a shock with 0 rebound versus building on with full rebound?
Old 06-29-2006, 05:26 PM
  #15329
0 rebound mean the shock should flow back full rebound i guess it does move back? i mean the shaft when u push it in
aus jd 2703 is offline
Old 06-29-2006, 07:57 PM
  #15330
IslandBwoy's Avatar
how? I've noticed that if i build my shock and screw the cap on tightly while fully pressing the shaft into the housing that the shock has less rebound; and similarly if i screw the cap on with the shock fully extended, the shock finishes with more rebound, but how do i get 0 rebound?
