Old 02-10-2010, 03:33 AM   #16
ben73's Avatar
Trader Rating: 40 (100%+)
I got my car last week and ran it friday night for the first time. previously ran the rc12r5
build quality is typical xray - excellent.
the small details on the car are much better than the AE car - I have all offroad AE cars and the fit and finsih on the XII are brilliant.
the shock is great - a much better unit than the rc12r5
car was good out of the box, quite agressive in the front end but by the end of the nights racing I had found a nice balance and got it working well. ended up 0.1 sec off the quickest lap times. the car has speed!
I did run the blue AE side springs on the car as Xray have not released any yet. funnily enough they fit almost perfectly on the spring holders....
ben73 is offline   Reply With Quote
Old 02-10-2010, 04:46 AM   #17
ian plimmer's Avatar
Ran mine last night for 1st outing and im pleased with its performance out of the box, played with cell position and main shock damping but apart from that the rest is built to the manual.this car has so much more corner speed than the t bar car.
also i didnt run the two spacers that xray recomend in the supplement sheet (under the cross brace) as i thought the side movement in the pod felt nicer without.
ARDENT RACING~MUCH MORE~D.R.C.M.C.C~TEKIN~GECKO TYRES
ian plimmer is offline   Reply With Quote
Old 02-10-2010, 05:36 AM   #18
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
Got my kit today and as always, I am highly impressed by the quality of the car.
As for other manufacturers copying other manufacturers cars - yeah - it happens blatantly sometimes - but for goodness sake - there are only so many ways you can design a 1/12th pan car.....have a look back to the original 1/12th's and subsequent kits from all manufacturers - not a whole lot has changed. You pay your money and make your choice, as much as some of us cry "copy" all the time - there are always innovations and better quality cars being produced. I for one will always save and or pay extra for a higher quality kit .....
Really looking forward to driving the XRay, although it has been nearly 20 yeas since I have driven a 1/12th!! WATCH OUT BEN - not because I am quick!!! LOL
Cheers
Darryn
Thanks to my sponsors for their support:
Team SCHUMACHER RACING - UK || B-FAST PERFORMANCE R/C USA || MAX RACING Products || BUGLE BOY RACING
"To know where you are going-you need to know where you have been" - www.darrynsretrorc.rtox.com
RETRO R/C is offline   Reply With Quote
Old 02-10-2010, 08:11 AM   #19
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I havent seen the instruction manual yet but I heard that it was in there to raise the cross brace 1.5 mm to take the preload off the side springs. This will help settle the car down a lot. We did this at the Birds. Also another thing to take the aggressiveness away from the front end is to cut about 2-3mm off the top of the steering block to lower the upper arm and remove camber gain. It will make the car a lot easier to drive and carry more corner speed.
Any more questions fire away and I'll try to answer best possible.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-10-2010, 10:06 AM   #20
ds400's Avatar
Default XII LINK
Hi guys,
getting my car today...
Heya do you have any building tips ?
What shock oil do you suggest for low grip asphalt?
Cheers
Didier
ds400 is offline   Reply With Quote
Old 02-10-2010, 11:56 PM   #21
Do you have enough and even amount of side flex to both left and right without spacers under the brace? We didn't. I also put 1mm shim under the brace to allow more movement. Before shimming the shock touched the cross brace and that limited read pod movement.
jarkko is offline   Reply With Quote
Old 02-11-2010, 12:02 AM   #22
Does the XII Link accept Associated spring in all locations, front, main shock unit and side springs? I believe Xray has not released their own shock and side springs yet.
I looked at Paul L. setup in the teamxray.forum and it seems that he used Assoc. springs all over the car.
Having tried I know CRC shock springs are too small in diameter.
Old 02-11-2010, 01:29 AM   #23
jarkko, my shock seemed to foul more with the spacers in
i and some fellow racers did agree that i got better pod movement without, maybe ive got a build issue here i need to take a look at
pehaps EA could shed some light on this but i will be trying the 1mm shims under there when i next run the car
Old 02-11-2010, 01:52 AM   #24
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
When you don't have springs ready.. why not use the industry standard.... lol
sounds like a good car.. might get one.. lol
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-11-2010, 05:49 AM   #25
Team EAM
AE Springs will fit eveywhere except the shock. Only xray springs fit the shock and the spring that comes with it is to soft for carpet. A hot bodies shock fits perfectly if you trim some off the shock shaft to get the correct length.
If you shim the cross brace you also must shim the top pod plate or the dampner will hit the graphite. This is probably what you felt.
The car is going to turn a few heads this year I believe. Just a few minor tweaks but it was really good at the Birds in all classes.
EA
Contact Us
Old 02-11-2010, 06:25 AM   #26
RC MARKET's Avatar
Yes is a good car !
RC MARKET is offline   Reply With Quote
Old 02-11-2010, 02:51 PM   #27
ben73's Avatar
the side springs fit however the xray holder is just slightly smaller so to be safe spend the 1.50 and just put the AE holder on and the side springs clip on tighter
as mentioned the main xray spring is larger than AE. I have done a whole lot of searching on the web and the springs I have found that look to be a perfect fit after measurement of the current silver spring are
HPI87277 HPI 11x28x1.1mm Shock Spring (Gold) (2)
HPI87076 HPI 11x28x0.9mm Shock Spring (2)
HPI87318 HPI Shock Spring Set (Soft) (6)
HPI87320 HPI Shock Spring Set (Hard) (6)
the dimensions on the tech sheet look spot on. and the selection is excellent. with all the above you end up with a choice of 8 springs....
Old 02-11-2010, 06:02 PM   #28
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
let me get this right...
You guys are using
Associate side springs
HPI middle springs
What about the front springs?
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 02-11-2010, 07:59 PM   #29
Scooby Horton1's Avatar
Asc
Trinity,EPIC,Oddy Racing,IRS,Sweep racing,Brown Engineering,Mugen USA,Team Xray,RC America,R.I.P. motorsports,Tekin,Customworks,Parma PSE,Ashford Hobbies,D&K Hobbies, TQ-wire,Local 69 Woodputters Union,Big Ant get well soon!!Quinn my BFF!
Dee Lee is a nut and I don't condone what he will say next!
Scooby Horton1 is offline   Reply With Quote
Old 02-11-2010, 08:03 PM   #30
hanulec's Avatar
Trader Rating: 27 (100%+)
Associated springs most likely -- they are the class standard...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Xray X10 World GT Car PitNamedGordie Electric On-Road 262 04-22-2010 03:18 AM
LINK VS T-BAR = Mateusz Purgal Electric On-Road 18 01-01-2010 02:45 PM
XRAY X11 link car mtbboy Electric On-Road 11 12-25-2009 05:12 PM
Xray XII 12th Scale Johnny Carey Electric On-Road 210 12-24-2009 08:18 PM
