Competition Electronics GFX Charger
I have had a couple weeks to play around with the charge and discharge functions of my new CE GFX charger.
To start, it has enabled me to increase my charge rate from 5A to 6A for stock racing batteries. Definitely like that!
Decided to use the Motor Mode feature to break-in and test a batch of four Monster Pro Stock motors. During the initial break-in at 2 Volts, I noted that 3 of the motors initially had a run current of about 7.5-7.6 amps which dropped to about 6.9-7.0 amps after two minutes of break-in time. Motor #4 runs about .3 amps higher that the other 3; but, it is labeled as having lower rpms and higher torque than the others.
Is there any important information to derive from this?
Would the lower amp draw motor be the best scenario...or worst?
Any additional thoughts about things to do with the GFX would be appreciated.
Unless the amp draw is really high, or really, really low, then you can't really detect any differences in performance between motors using the amp draw feature, especially with differences that small.
Company Representative
TSR6 is 100% correct...
Also, if Amp draw is to high, is it sign that something is not right...
A lot of guys relate Amp draw to torque of the motor....
True, to create more torque you need more amps......
But, it is not a dyno....
In general I listen to the motor for RPM and look at the amp draw..
Each Brush/spring/motor combo will be a little different..
Another thing to do is feel the motor for vibration during break in...
Originally posted by STLNLST
XXX-S Bill- are you practicing in stockton on Friday? If so come and find me. I'll be more than happy to give you some help. Good luck this weekend and let's have some fun.
Still expecting Todd Hodge to show too. Gonna be a SHOW!
Be there on Sat-Sun.
Thanks.
HE is the one THEY call the 19t KING! Just ask anyone if they know who the 19t king is, they will point you in his direction.
Today before the main, I was debating on replacing brushes. It was the 3'rd run on the brushes, but I could only get them to pull about 7.1 - 7.2 amps through my T-35 after deglazing them with a fiberglass stick. I took them to a buddy who has a grinder to re-surface the brushes ( not a re-serrator ), after re-seating the brushes, they would still only draw about 7.4 amps. I still ran the brushes, but I definately had a lack of power.
Originally posted by TSR6
For example:
For example:
What voltage are you running the motor at when getting these readings?
Originally posted by XXX-S Bill
Thanks TSR6. I appreciate the extra details.
This was a binary motor, with cut brushes. New with the cut I use, they should draw amperage in the low to mid 9's.
2 volts.
2 volts.
Hmmmm. Would the binary have significantly more torque than a Monster Pro? Checking because all my readings are in the 7's at 2 volts, I don't quite relate to drawing power in the 9 amp range.
I am running a pretty odd-ball setup on my motor for brushes and springs. Each motor, and each motor setup will have a different amp draw, so you just need to find your own base, and go from there.
