Competition Electronics GFX Charger >
Old 03-08-2004, 10:39 PM
Trader Rating: 16 (100%+)
Default Competition Electronics GFX Charger
I have had a couple weeks to play around with the charge and discharge functions of my new CE GFX charger.
To start, it has enabled me to increase my charge rate from 5A to 6A for stock racing batteries. Definitely like that!
Decided to use the Motor Mode feature to break-in and test a batch of four Monster Pro Stock motors. During the initial break-in at 2 Volts, I noted that 3 of the motors initially had a run current of about 7.5-7.6 amps which dropped to about 6.9-7.0 amps after two minutes of break-in time. Motor #4 runs about .3 amps higher that the other 3; but, it is labeled as having lower rpms and higher torque than the others.
Is there any important information to derive from this?
Would the lower amp draw motor be the best scenario...or worst?
Any additional thoughts about things to do with the GFX would be appreciated.
Still Bill is offline
Old 03-08-2004, 10:58 PM
Speedo's Avatar
Unless the amp draw is really high, or really, really low, then you can't really detect any differences in performance between motors using the amp draw feature, especially with differences that small.
Speedo is offline
Old 03-08-2004, 11:09 PM
RCTech Member #2
TSR6's Avatar
The main thing i use the amp draw feature for is to see if i need to rebuild the motor. Fresh, my motors will draw between 7-9a depending on the motor and brush cut. I know that if it's drawing really low for that individual motor, that i need to cut it, or at least de-glaze the brushes.
TSR6 is offline
Old 03-09-2004, 06:52 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
TSR6 is 100% correct...
Also, if Amp draw is to high, is it sign that something is not right...
A lot of guys relate Amp draw to torque of the motor....
True, to create more torque you need more amps......
But, it is not a dyno....
In general I listen to the motor for RPM and look at the amp draw..
Each Brush/spring/motor combo will be a little different..
Another thing to do is feel the motor for vibration during break in...
Tres is offline
Old 03-09-2004, 06:53 AM
STLNLST's Avatar
Trader Rating: 32 (100%+)
XXX-S Bill- are you practicing in stockton on Friday? If so come and find me. I'll be more than happy to give you some help. Good luck this weekend and let's have some fun.
STLNLST is offline
Old 03-09-2004, 07:02 AM
Gotta work on Friday...Drat!
Still expecting Todd Hodge to show too. Gonna be a SHOW!
Be there on Sat-Sun.
Thanks.
Old 03-09-2004, 07:04 AM
STLNLST's Avatar
Thanks.
come find me when ever you have a chance. We'll get you squared away.
STLNLST is offline
Old 03-09-2004, 09:56 PM
Thanks all. This has been really helpful.
STLNLST,
See you at Stockton...If I can figure out who you actually are...he, he...
Sure we will have plenty of time between rounds...more he, he...
Bill
Car #76
Old 03-09-2004, 10:03 PM
HE is the one THEY call the 19t KING! Just ask anyone if they know who the 19t king is, they will point you in his direction.
James Nguyen is offline
Old 03-09-2004, 10:17 PM
RCTech Member #2
TSR6's Avatar
For example:
Today before the main, I was debating on replacing brushes. It was the 3'rd run on the brushes, but I could only get them to pull about 7.1 - 7.2 amps through my T-35 after deglazing them with a fiberglass stick. I took them to a buddy who has a grinder to re-surface the brushes ( not a re-serrator ), after re-seating the brushes, they would still only draw about 7.4 amps. I still ran the brushes, but I definately had a lack of power.
TSR6 is offline
Old 03-09-2004, 10:19 PM
Ah ha!
Thanks James.
Old 03-09-2004, 10:22 PM
Originally posted by TSR6
For example:
Thanks TSR6. I appreciate the extra details.
What voltage are you running the motor at when getting these readings?
Old 03-09-2004, 10:24 PM
RCTech Member #2
TSR6's Avatar
2 volts.
This was a binary motor, with cut brushes. New with the cut I use, they should draw amperage in the low to mid 9's.
TSR6 is offline
Old 03-09-2004, 10:33 PM
2 volts.
Hmmmm. Would the binary have significantly more torque than a Monster Pro? Checking because all my readings are in the 7's at 2 volts, I don't quite relate to drawing power in the 9 amp range.
Old 03-09-2004, 10:41 PM
RCTech Member #2
TSR6's Avatar
My monster stocks would usually draw mid to high 9 amps. My Binarys draw slightly less amperage than my monster motors did with the same brush cut.
I am running a pretty odd-ball setup on my motor for brushes and springs. Each motor, and each motor setup will have a different amp draw, so you just need to find your own base, and go from there.
TSR6 is offline
