Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1953
What's up Paul? Been running the T4 a about 6weeks now and I'm loving it (mostly)
I'm running in Nashville where EA runs. What I've noticed about the car is that on med-high traction we r getting a lot of build up on bottom of chassis (both sides ) and we have the actual Vegas track and carpet for a few yrs back . What would u do to keep this rubbing to a minimum or at least keep it from building up as think on chassis ?
Set up is :
Front ;kit set up except 2mm shim under outer links and 0 under inner in #2hole
Rear ; kit set up except high role blocks , 5mm under outer link ,.5mm in front of arm 2mm Behind arm (kit 3mm of shims kept arms bound up on my car )
Ride height is 5.4F/5.8R with 1.5uptravel in front /2mm rear up travel
Cars weight bias is about 48%F/52%R(1382g)
Ea6500/70batt / duo 3.5 tq rotor 3.8fdr / futaba bls551/ airtronics MT-4 / lrp sxx v2 spec (no heat sink version)
EA is running a 10.32 fast lap / I'm at 10.57 at best .
Tkanks in advance for any help
Set up is :
[QUOTE=PROMODVETTE;11526265]Would this be the same on a t3'12 with a ltcr in 17.5?[/
Promodvette: sorry, sometimes this thread can get just as unimformational as it is informational. The post was a joke with "express" who was a team mate of mine from the late 1990's, that was some stuff we used to do. You don't want to do that stuff. Thanks!
#1955
Great, thanks for the input!
#1956
hello paul
why not use thunder power lipo battery with dean's no more
greeting peter
greeting peter
#1958
thanks!
#1959
Tell me what it means when ur tires r squealing . I my self seem to run faster when my tires r screeching coming out of the corners . But the fastest guy here (on carpet) said its scrubbing corner speed . And his car is dead silent... can u comment about a this tks paul
#1960
#1962
Speaking of loose is fast...
I'm running a T3'12 in VTA. I like that is is loose, but in the later minutes of the main it gets a little too loose to the point it does slow. I need to tighten up the rear just a little. What kind of change could I make to just tighten it a little?
#1964
