Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#1786
Hi Randy, I did use the servo mount on the old car. with a servo saver it worked fine with just screwing the servo on with the tabs. with a solid servo horn the servo will move on the screws under impact. so with a solid servo horn i also servo taped the servo to the upper graphite piece and screwed it in by the ears. That seemed to cure it for me. Hope that helps!
#1788
That's between flowing outdoor tracks with Sorex 32's and tighter indoor tracks on Sorex 28's. It's been working well lately
Skiddins
#1790
Hey man. I dont think so as of right now, sorry
Hi Craig, Missed it. maybe next wed ill come check it out.
Normally you just need more steering on asphalt, so normal changes for asphalt would be more front camber, less rear camber, less rear toe, shorter wheelbase in the rear or more weight back on the chassis. that is a start if your car is pushing on asphalt. Thanks!
LOL, I don't remember but i do look pissed huh, lol. It couldnt have been that bad.
#1796
wish i had a more accurate way to explain it.
#1797
Paul, I know you were going to try cars with and without the new central servo mounting method. Did you prefer it or not find any difference.
Skiddins
Skiddins
#1799
Hi, the side springs that i had on my car are sold By RC America as a kit of 5 different springs. red is a med/soft spring.
Their is no tool or sound method for setting belt tension. I know this is not a good way to explain it AT ALL!!. But you dont want them tight and you dont want them loose. but you want the front a little tighter than the rear.
#1800
Bb
