Ask Mike Blackstock
#136
STLNLST.. For carpet racing i use a diff. For big wide open outdoor tracks i use a one-way. For tight hard tracks i usually will run a spool... I do not think the spools are harder to drive then a one-way. My opinion with the car setup the spool is much easier .....
trackdesigner71. IF associated wanted me to come then i would go. But that all depends on other races and schedule.. I have a 2 yr old i stay at home with so time my time is golden...
RAY... Awesome news.. Let me know if there is anything i can do for you....
Brandon Melton. I use the long neck one... Right now i am running my Cleveland setup . No adjustments just yet.. Remember this is the same carpet as the champs used... If i find anything out i will post it on here... Glad you liked it. Seems to be a good baseline for most people then they can adjust from there..
Mike
Mike
#138
Spool
I just want to share, with the indulgence of MikeB:
I use an associated spool for the TC3 and the car handles great with a LOSI 6degree C-hubs!!!! Great turn in and exit! Plus the loads of on power steering! Well this is what I experienced.
Plus the set-ups that Mike Blackstock posted, helped me to get the 1st in B-main!! (i usually finish last!)
Thanks MIKE!!!!!!!!
Peace and Happy Racing!
Lem
Thanks MIKE!!!!!!!!
Lem
#139
Mike
Mike
#140
Mike,
Did you use the AE front steering hubs for your cleveland setup or Losi?
#141
STLNLST.. Here is a setup we used at the onroad nat's in colorado with a spool....
http://www.rczone.net/files/associat...ker_mhor02.pdf
you might have to create a user to get it. But it is a good starting point for the spool. Barry kicked everyone's but with it. I ran 6th or 7th with it ...
trackdesigner71.. Thanks.. Hopefully the race will be a success for you....
LEM2... Congrats.. Gald i could help....
OB42TC3.. I run associated steering blocks.. I have played with losi castor blocks for the strength of graphite VS plastic....
Mike
Mike
#142
Hey MIke,
I posted a pic on the hobbytalk thread. Can you take a peep at it sometime and tell me if you see any wiring hiccups on my part. I talked to Robert and he assured me I can run the 301 RX in high speed-3ch mode no problems at all!!!
I'll leave the 302 RX in my 12th scale car to get the highest speed response.
Thanks,
Ray
Thanks,
Ray
#143
Mike, you being a Novak driver of some time, what do you think is the best profile on the GT7 for Stock Foam TC? Mod Foam? I know you said in an above post not to change profiles to go to mod, but I am just wondering. Right now I have been running either profile 4 or 5 in stock and I cannot seem to tell much of a difference. Your thoughts?
#144
Brian McGreevy.... I run profile 5.. I never change it for stock or mod....
Mike
Mike
#148
hey mike just a couple of questions. according to the GT7 instc. profile 5 is oval
also If I am loosing the rear of the car getting into the corner does that mean that i am transfering to fast to the front.
I like the way the car turns now just need to tighten it up getting in. I am running 4 rear droop was thinking of going to 3 would this help
oh yah ever see
oh yah ever see
#149
Here's a question for you Mike:
I'm going to run a the nats next week, and I want to get my tires ready. One friend says just cut them to race size and use new tires every round, from truer to track. the other says to break the tires in 5-6 laps after truing. This would be for stock. Any advice?
#150
oh yah ever see
oh yah ever see
Recommended Throttle Program Summary:
Best Over-All: Throttle Program 5
Slick Tracks: Throttle Program 4
High-Traction Tracks: Throttle Program 6
Most Stock Motors: Throttle Program 6
I think adding more rear droop would transfer more weight to the front and lose rear traction. You might try 5mm rear droop.
P2
