GM Speed control HELP! >
Old 03-05-2004, 07:55 PM
Formula1fan's Avatar
Default GM Speed control HELP!
I have a SX9 speed control in my 1/12th scale. Every three minutes or so the car cuts off. You can still turn the wheels, but no power to the motor. After thirty seconds it will work fine for a few more minutes and do the same thing. Has anyone had trouble like this?
Formula1fan is offline
Old 03-05-2004, 10:23 PM
lowline's Avatar
Default tc3
I have a gm speedo great speed control i have'nt had that problem with it but did with a cyclone it had a bad mosfet could be the same not sure may need to send in.
lowline is offline
Old 03-05-2004, 10:45 PM
slowhand's Avatar
Default GM ESC
Formula1Fan: It is a common problem found in the GM SX series, due to the heat protection system circuitry. I'd like to suggest you check your motor, gear ratio etc.
The Yokomo spec of SX9 or SX12 do not have this problem and can run 'hotter' (that's why Yokomo call it 23T spec i.e. can be run with high gearing ratio commonly used in 23T racing. But it doesn't mean that the ESC can run only up to 23T)
Hope this helps ...
slowhand is offline
Old 03-05-2004, 11:34 PM
Gutter Ball's Avatar
8 of us had SX-9's that did the same thing. Just randomly quit running for no apparent reason. If you went over a corner dot, it would stop instantly. One guy sent it back to Horizon and they sent him an SX12. The repair person actually called that guy and told him to tell us to send ours back in too because we all probably got a bad batch. Overly sensitive thermal protection. So I sent 3 of mine (yep, 3. 2 in Carpet Knives and one in my Mini-T) back to Horizon explaining the problem and 2 weeks later I have 3 new SX12's. Email Horizon's service and they'll take care of you.
Gutter Ball is offline
Old 03-06-2004, 03:01 AM
I never had huge heat problems with my SX9, but it did sometimes get a bit upset when the supply voltage got a bit low. It is a heat problem though as i had the problem in my touring car.
I now have an SX12 and it has been spot on in all cars that it has run in.
MattW is offline
Old 03-06-2004, 03:18 AM
dragon26's Avatar
Default SX9 instructions in english
If anyone has sx9 instructions in english could they post them here. The translation from the manual is well pretty much useless.
thanks.
dragon26 is offline
Old 03-06-2004, 06:24 AM
Chrisgt2's Avatar
SX12 is definately awesome.......got mine as a result of a bad sx9 too
Chrisgt2 is offline
Old 03-06-2004, 06:55 AM
V12
V12's Avatar
From what I have heard there were some little problems with the software of the SX9 from the first batch. Later versions seems to be OK and SX12 doesn´t have any problems.
V12 is offline
Old 03-06-2004, 08:19 AM
I am going to send it back today. Thank you all for the help!
Old 03-10-2004, 03:46 AM
So who repair these esc. I send my v12 xc to horizon hobbies and they just sent it back to me. does any know who can repair them
ptjonesus is offline
Old 03-10-2004, 07:57 AM
V12
V12's Avatar
Did they say why they send back the V12XC? Horizon is the GM-Racing distributor for the USA so they should care for repair.
V12 is offline
Old 03-10-2004, 10:38 AM
speedxl's Avatar
pt they are the repair guys you must have killed the esc because they are pretty good about fixing it.
i had the cutting out condition on my sx9 and they were kind enough to replace it with the sx12 its odd they would send it back to you with out be repaired or or atleast offering an upgrade!
speedxl is offline
Old 03-10-2004, 01:25 PM
war11x's Avatar
Trader Rating: 17 (100%+)
Default GMV12 ISSUES
HAS anyone had issues with thier GMV12 with ,surging power current
mine seems to run well at times and not so well other times
i true my comm every meet and install new brushes so it cant be any thing to do with the motors ( i run monster pro and P2K2 pro from Paradigm) , is thier a fix ?? other then purchasing another one ?
cheer s
war11x is offline
Old 03-10-2004, 01:30 PM
Nova F1 Racer's Avatar
Default Re: GMV12 ISSUES
cheer s
DO you have the power capacity installed?
Is it loose?
On the right terminals?
Mine got loose and the ESC shutdown until I re-soldered it back on...
And NO DIODE!!!!!!!! Very bad things will happen if one is installed.
Nova F1 Racer is offline
Old 03-10-2004, 01:35 PM
war11x's Avatar
Default Re: Re: GMV12 ISSUES
Is it loose?
DO you have the power capacity installed? NEW ONE INSTALLED
Is it loose? NO
On the right terminals? YES
and a new diode fitted 2 weeks ago
i had replaced these item in the past and the issue is still thier
the Speedy looks like new still and has not been subjected to any real big hits
Warwick
war11x is offline
