Like Tree3Likes
Xray T1
Old 01-01-2009, 10:28 PM
  #12181
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Originally Posted by minittrackmann
HEHEHE.
Yeah hows that servo working out for yha?
Cody
I race in a parking lot series that also includes nitro sedan and Inferno GT's, so the layouts are fairly large and open (usual layout is 180x90), so I don't think it really hurts the car's performance. It actually makes for a car that is easy to be fast with, especially in 27T/13.5T classes where momentum is so important and where smooth is fast. A faster, digital servo *will* be my next upgrade though, and then lipo once someone makes an SMC-sized saddle pack with bullet connectors
-rocky b
flatspunout is offline
Old 01-01-2009, 10:36 PM
  #12182
minittrackmann's Avatar
BTW I love how you have that saddle pack conversion. Did you do that yourself?
Hows the weight distribution?
Cody
minittrackmann is offline
Old 01-01-2009, 10:45 PM
  #12183
Cody
It's actually the Factory Kit version (FK04) of the T1 Evo 2 which is a saddle-pack car. The FK adds a C-hub conversion and I believe came with a front diff instead of a one-way. 05 brought the battery on one side, electronics on the other config. I really like the saddles, it makes balancing a breeze but also makes motor cooling more difficult, and lipo choices (at least ROAR legal ones) are slim...I think that will change though as I see more and more manufacturers bringing them out.
-rocky b
Old 01-02-2009, 10:51 AM
  #12184
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
t1 forsale with BMI 350 chassis http://www.rctech.net/forum/r-c-item...road-oval.html
20 SMOKE is offline
Old 01-02-2009, 01:29 PM
  #12185
Man i'm building my fk05 shocks and they are such a pain. !!!!
Cody
Old 01-02-2009, 01:51 PM
  #12186
blast's Avatar
Trader Rating: 28 (100%+)
Cody
yea that bottom cap is fun to deal with
blast is offline
Old 01-02-2009, 02:46 PM
  #12187
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
i will be building my old T1 FK04 for a friend tonight for VTA my son drove this car till i gave him my 007
but we are equiping it with GTB,hitec highspeed servo, rs300rec,21.5 BL
and a reedy 5000 lipo stick pack i must weigh the electrics against the battery to see which will be going on the motor side(the lighter of the 2)
also i will be makeing a brace to protect the lipo from slinging by cutting up a old chassis h.k.s.hobbies sales one(atomic lipo strap) but i cant get it in intime i have used 3 of them so far and love them
i will post soem pics tomorrow
jlfx car audio is offline
Old 01-02-2009, 03:00 PM
  #12188
Absolutely they are a pain...but get it right and they are like buttah!
-rocky b
Old 01-02-2009, 03:30 PM
  #12189
here is the KF05 we diod this past weekend
we polished ALL the aluminum
i dont know if the pics shpw it but it looks like crome
also it has a ATOMIC battery strap (for a 008)on it
it allowed us to set the lipo out for ballast to keep us from adding weight (we run vta and only need 1450
this car balances out with 10g added on electronic side @ 1452
Old 01-02-2009, 07:09 PM
  #12190
Nice setup you got there. I love that blinging lipo!
Old 01-02-2009, 09:01 PM
  #12191
For 19 turn racing what would be the best gearing, running on asphalt, with 26 mm tires.
Also how do I no if the gear is 64 pitch or not?
Cody
Old 01-02-2009, 11:25 PM
  #12192
Cody
Track size will determine gear...so give us the dimensions and we can figure a good starting FDR. 64 pitch gears have 64 teeth per inch, so the teeth are much smaller than a 48 pitch gear (48 teeth per inch) or a 32 pitch (32 teeth per inch). The pics of Chris' Evo2 on the previous page show 64 pitch gears. Onroad cars typically use either 64 or 48, with 64 giving finer tuning of the gear ratio and 48 giving a little better durability, especially for parking lot racing where the track surface isn't as well groomed or prepared as a dedicated race facility. I tend to chew them up equally so I run 64p
-rocky b
Old 01-03-2009, 08:00 AM
  #12193
Ok, well I now no I am running 64 pitch. I am going to the track later and I will take a picture of it. It is fairly large. I run at Jacksson Rc. It was also just repaved with high grade tennis court asphalt.
Cody
Old 01-03-2009, 06:43 PM
  #12194
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's http://www.rctech.net/forum/electric...ox-ratios.html
RielTime Racing is offline
Old 01-03-2009, 07:44 PM
  #12195
hear is the T1FK04 i just got done rebuilding for VTA
i had to add 33g to the electronics side because i could not get the battery any closer to the center it is 1455g
