Xray T1
#9242
Re: Re: Re: Re:
Originally posted by 840918001
Hi,
Thanks all for the reply's
I'll firts try the trick opted by theisgroup.
If that doesn't work I will use the cutting wheel
Thanks all
Thomas
Hi,
Thanks all
Thomas
i have doen this a few times with great results and No Damage
Cheers
ps just take your time with the drill / dremel
#9244
Originally posted by JDXray
I was thinking of getting those low ratio pulleys because at the track i run at right outta the corner you need torque, not so much top end. I am doing fine the top end part, just need alittle extra push so i can make my way up during a race.
In the future i am thinking of getting the FK but i will wait for now since i am running well with my T1R.
What should i gear a Reedy Quad Mag/ CHameleon 19t motor at with a 120-124t 64p spur gear? I guess i will start small and make my way up if i feel there is a need too.
Jon
Jon
#9245
Originally posted by EAMotorsports
Hey Mike,
The new Factory shock tower has a set of holes to make the camber link super short....should work great on carpet.
RCMushroom has the ackerman extensions and the front shock tower in stock.
EA
Hey Mike,
EA
I appreciate the info and I just checked them out and they have a ton of parts...well that is at least what their web site says...LOL
Thanks, Mike
#9246
mike ygpm.
#9247
Stripped screws
Sears makes a tool that you connect to a drill that locks onto the screw head and takes it out...... I have tried it on some other screws with REALLY good success... I even got one for my lhs so that they could use them!!! Try it. I have done the dremel thing and ended up damaging parts that way..........
http://www.sears.com/sr/javasr/produ...id=00952154000
Try it out!!
Try it out!!
#9248
Guest
Hey guys !
Need help here. I wanna to use T1's universal drive shaft on my Yok and are all the drive shafts front and rear the same length ??
Thanks in advance.
Bryan
Thanks in advance.
Bryan
#9249
yep they are the same length im using the rears in the front of my xray
#9250
I have just built a T1FK and would like to know what size of spur gear I should get. I use 64 pitch gears and my Pro4 spurs are too small.
#9252
Originally posted by tornado
Hey guys !
Thanks in advance.
Bryan
Hey guys !
Thanks in advance.
Bryan
#9253
Stripped screws
Hi all,
I want to thank everbody for the tips I recieved.
I have started this afternoon with changing the screws.
It took some time, but I haven't demagged one bulkhead or the chassis plate and upperdeck
Thanks again, Thomas
#9254
#9255
The precision gears are awesome. Difficult to find though.
